RV.Net Open Roads Forum: Class A Motorhomes: car rental vs towing
 > car rental vs towing
backroads???
south carolina
Posted: 05/29/13 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
We use our rv for short trips (week or two) 3or 4 times a year.Should I invest in a tow setup or just rent a vehicle at my destination? I would rather pull my boat. Anyone doing this? could realy use some input. Thanks in advance for your help..JB
KazooTom
Kalamazoo, Michigan
Posted: 05/29/13 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
In my case it would cost somewhere north of $2000 to set up our car to tow. So far we have been successful in renting at our destination. Our preference has been Enterprise as they regularly do pick up and drop off. That saves us having to deal with trying to maneuver our motorhome in their lot.
If we were traveling for longer periods of time towing would probably be a more logical option for us.
Tom & Barb
'07 Winnebago Voyage 35L
Workhorse W22 Chassis
rgatijnet1
Posted: 05/29/13 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
I guess it depends on where you plan on traveling. If it is near an area where car rentals are handy, then rent. I assume that you plan on using your coach to launch your boat, which may be a hassle to leave the RV Park, launch the boat, and then come back later on and hook up at the park again.
the bear II
Torrance CA.
Posted: 05/29/13 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
Eventhough we have a 5th wheel and have the truck to use for getting around, there are times when we rent a car for sight seeing and other trips. It saves having to drive one of our cars separately to the campground.
I would calculate how often you might need to rent a car and then do a cost comparison to see where the break evan point might be. Keep in mind eventhough you may tow the car there will still be some maintenance costs to consider..tire and brake wear on the car as it is towed.
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 05/29/13 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
I think it comes down to how much hassel is it to be without a toad maybe more than the cost. How far from your camping spot do you have to go to get the car and then take it back? How do you get to the car rental place - drive your MH? Do they have parking for it? How much time will that take to get the car and then return it. What if you're all set up and then you're out of bread or propane? Everyone is different. Try it a few times without. Enterprise seems to work fairly well if you camp near towns. You can always start pulling a toad if it doesn't work out.Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
JimM68
Yorkville, Illinois
Posted: 05/29/13 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
Our motorhome never moves without the wrangler toad behind.
The boat for sure could add some questions though. I like boats, would not have to choose between a boat and the wrangler.
Jim M.
2008 Monaco Knight 40skq, moho #2
The "68"
My very own new forumfirstgens.com
My new blog
Effy
NC
Posted: 05/29/13 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
It sounds like from your question you'd rather pull your boat and rent a car. Otherwise you tow your car and have no boat. If you rent a car you have both. I don't have a boat so the decision was easy. Tow it. I would much rather have my own car that I know has not been smoked in, can be packed with stuff and is an extra vehicle in case I get stranded. Not to mention it's free aside from the initial cost of setting it up. At a rental of $50/day (guessing but I'd need a larger vehicle), I'd only have to rent 4 weeks to equal the cost of my dolly.
2013 ACE 29.2
mfox20
Fort Worth, TX
Posted: 05/29/13 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
I use mine about the same as the OP. Most of the time we travel to the same few destinations where renting has been easy with Enterprise. They come the campgrounds and pick us up and return us when we are done. I usually pull a cargo trailer with a golf cart on those trips as well.
So renting has worked well for us so far. Usually spend about $80.00 to $120.00 for 3 or 4 days of rental.
I recently purchased a new Honda CR-V that will become the toad later when we travel more frequently to new destinations.
Michael
Michael
2000 Holiday Rambler Endeavor Gasser
2013 Honda CR-V Toad
wildtoad
Blythewood, SC
Posted: 05/29/13 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
If you will mostly go where you don't need a car, then renting is a good option for those times that you do. I have been places where there is no rental agency, and only one cab for the whole town. We do not tow, but if we stay within the state (SC is not that big) the wife will typically follow in her car.
If you decide to tow then you have the issue of 4 down, trailer, or tow dolly and all methods have their pros and cons.
Tom Wilds
Blythewood, SC
crasster
Dallas
Posted: 05/29/13 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
I prefer to tow because if there is a break down between nowhere and small town usa, there is a way to get around.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
