RV.Net Open Roads Forum: Class A Motorhomes: External Septic Tank
 > External Septic Tank
revump
Deer Park, WA or Las Vegas, NV
Posted: 05/29/13 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
When we built our house with a basement, a hold tank with a pump was installed to pump sewage to the house septic tank. I would like to do that for an RV pad, drain my black water tank in a holding tank and pump it to my septic tank ... any ideas would be helpful.
Bob
sch911
Rochester Hills, MI
Posted: 05/29/13 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Start with your local building department and zoning board. Make sure they approve it first!
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2007 Jeep Grand Cherokee Limited Toad
Dutch_12078
Winters south, summers north
Posted: 05/29/13 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Why not just pump it directly from your existing RV holding tank to the septic tank? A macerator pump would likely handle the job within a reasonable distance and rise. You could even bury a hard line rather than running a hose.
Dutch
2001 GBM Landau 34' Class A
rv2go
Fulltime 15 yrs (Knoxville, TN).or someplace else
Posted: 05/29/13 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
I built something like THIS about 10 years ago. I have pumped 6' uphill for 100' thru a 3/4" hose.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
Bumpyroad
Virginia
Posted: 05/29/13 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
when you approach the various utilities, remember you are putting in an additional "clean out".
bumpy
korbe
California
Posted: 05/29/13 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
Are you pumping the whole thing, or just the effluent? I would not grind the solids and then put it all into a septic tank. I would first attempt to utilize what is existing. If not, a new septic tank and separate effluent pump would work.
revump
Posted: 05/29/13 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
Pumping the whole thing and draining the grey water tank too
revump
Posted: 05/29/13 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
In the basement of our house, it pumped the septic out of the basement and into our house septic system. Our septic system is a long way from the rv pad. Right now, we have to drive about 8 miles to dump our tanks
korbe
California
Posted: 05/29/13 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
You can install a two chamber septic tank near your RV pad. Install a typical drain ( like you hook up to at a park) and run the drain line to the tank. You can install a duplex pump system in the second chamber of the tank. When set up, the pumps will alternate and pump the effluent up to a new distribution box, and then to your leach lines. Or you can put in another system similar to what you have in the basement, and pump it all up to the existing septic tank. All of which requires permits from the local jurisdiction.
rockhillmanor
On the Road
Posted: 05/29/13 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
Is that a garbage disposal!? VERY cool DIY![emoticon]
That could so be used at CG's. I couldn't believe the last trip down south how many CG's I stopped in that in the pull thru's, once you are all the way in the site you can NOT reach the sewer.
That little bugger would be great for incidences like that!
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
