RV.Net Open Roads Forum: Class A Motorhomes: Dead Battery On CR-V
 > Dead Battery On CR-V
zman-az
Northern AZ
Posted: 06/07/13 10:08am Link  |  Quote  |  Print  |  Notify Moderator
Maybe you should reread these posts. They can help you with your problem.
here
and here
doc brown
Redondo Beach, CA,
Posted: 06/07/13 10:19am Link  |  Quote  |  Print  |  Notify Moderator
2chiefsRus wrote:
Toad Charge
We have been very happy with the Toad Charge. Comes with everything you need.
x2 great product
Steve,Kathy and Josh
Morpheus(Basenji)at Rainbow Bridge
2004 40' TSDP Country Coach Inspire DaVinci
350 Cummins, 3000 Allison
2014 Jeep Wrangler Unlimited Sport S, Air Force One Braking, Blue Ox
aerbus32
california
Posted: 06/07/13 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
I came up with a very simple solution. After the original equipment battery went dead, I replaced it with a very good battery from Costco. Typically, I stop about every 2 hours for a quick break. First thing I do is fire up the engine of the 2010 CR-V and run it thru the gears as per the owner's manual. I let the engine run whole I do whatever else needs done - typically just a visit to the restroom - then turn it off. When I get to the RV park, we do take the car for a drive to explore and maximize the batteries charge. Just drove from So Cal to Redding with 2 overnight stops. Today, drove straight through without starting the car from Lodi. That's over 4 hours. It started just fine.
wny_pat
Western NYS
Posted: 06/07/13 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
Remco Towing says: "When towing for an extended period of time, start the vehicle as often as possible and allow it to run for five minutes to prevent battery drain." and "When towing for long periods, remove 7.5-A accessory radio fuse.aaaaaa"
“All journeys have secret destinations of which the traveler is unaware.”
Livies Dad
Indian Trail, NC
Posted: 06/07/13 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Did Honda change something on the crv from 2006 to 2007 up? I have towed a 2006 crv almost 50k and never have pulled a fuse or had a dead battery. Have pulled as much as 4 days with out unhooking but do
start it each evening when parking and each morning before leaving.No\charge line either.
Mr.Mark
Out West and Mid South
Posted: 06/07/13 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
I think the 'pull-the-fuse' requirement is due to the fact if your car has the navigation option which we had/have on both of our Honda CR-V's. With the Nav/radio set up, you cannot turn off the system when the key is in the accessory position, hence, the removal of the fuse.
MM.
Mr.Mark
2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo w/1,750 lb. ft. of torque, 1.5 baths, 4 slides.
2017 Lincoln MKX AWD 335 hp twin turbo.
MrBrett
North Carolina
Posted: 06/07/13 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
We pull an 08 CRV and also use the Toad Charge system. Easy to instal, works great, no need to pull any fuses. Plug it in and go.
2007 American Eagle 45H
2008 Honda CR-V (toad)
2012 Victory Cross Country Tour (motorcycle)
