It's home! My wife took pictures and notes the entire review, we saved video on the ipad of each componet and towing set up. Towing with WDH and Sway control was calm but not too fast, raining heavy on way home. One question that we have is running the hot water heater on Gas vs. electric, my guess is quicker recovery on gas but using the CG's electric would have some upside on saving LP. Anyone notice a difference between the 2 systems in performance?
BTW- the tech was awesome and spent over 4 hours no concern or question left by the time we were ready to leave.
just a comment, that trailer is going to be an issue for your Taco, when you start getting in the mountains. with an actual weight of around 4500lbs. from the factory, you can easily be in the 5500lbs. loaded for camping range.
that v-6 can probably handle the flats but it will struggle in places like the Rockies or Sierras or a strong headwind.
Dan- Firefighter">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 Ecoboost, 2016 PrimeTime TracerAIR 255 w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
My understanding that the WH does recover faster on propane than electric. DH just flips the switch to the WH during regular set up so it's ready whenever we are. Have never had a problem running out of hot water either showering or dishwashing....just getting used to turning the water off and on rather than letting it run. Same thing with the frig - cools faster on propane, but changes over to electric at the CG. We've never needed to speed up either process. We figure we're paying for electric with the site fee, so that's what gets used.
Trailerless but still have the spirit
2013 Rockwood Ultra Lite 2604 - new family
2007 Rockwood ROO HTT - new family
2003 Ford F-150
4 doggies - We support Adopt/Rescue.
Sam, you were the best!
Cubbie, Foxy, Biscuit and Lily - all rescues!
Weekend went great thanks for all the help on walk through. Had to check the notes a couple times but overall no crisis. Electric HW was more than enough for our needs' it is very hot, did not expect that much temp. What a difference from the pop up on having hot water! Found I still like to cook outside, may need to upgrade my outside kitchen to newer gas stove. I did not get an outside gas hook up on the camper, has anyone spliced one in? Would need a flaring tool and hardware but thought I'd check if its been done aftermarket.
As for the Taco, three things it will never see while towing- 7000 ft, 70mph and 5th gear :-). We knew that going in so no surprise. It's the perfect truck for us 95percent of the time and we'll take it real easy while towing. Very stable, just underpowered for sure. That said, we towed the pop up with 1988 5.0l Chevy truck with 175hp and 3.08 rear and the taco feels like a diesel compared so all perspective I suppose.
Thanks all, let me know if you mod'd a camp stove. For now a tank stand will work just fine.
My second time around I would take it for a test drive. The brakes vibrate on mine and I have yet had luck getting the dealer to want to fix them. They lied to me and said it was normal. I didn't know better at the time. Next month I'm going somewhere else and getting them fixed regardless.
Taking a video is a great idea. Easy to forget stuff.
LOL at the awning comments. That so happened to us. Forgot how to put it out and was unhooking things I should have left alone. Almost shoved the awning into the camper windows. Lessons learned but now I can do the awning like I'm a pro.
Make sure if they install your receiver that it is properly torqued or risk what happened to me.
Partner this is what we did, I had my dealer have their Lead Mechanic show me how to troubleshoot basic items associated with my particular htt. Now that was as he was also walking me through operator orientation, ie' manual slide crank arm location, H2O filter location, electric tongue lift over ride, does the mattress have heat. Another thing the wife and I did was talk to the parts staff prior to even seeking help with sales department, they know what models are having the costly repairs, recalls, and the sort. Go looking on rain , snow, windy days. This way you can inspect the quality of the equipment.
Retired Marine with Retired Navy woman2004 Fleetwood Pace Arrow 37 C, Workhorse p32 chassis, 8.1l gas engine.
