RV.Net Open Roads Forum: Class A Motorhomes: Porch Light and Handle Light
 > Porch Light and Handle Light
Lobstah
Gulf Coast
Posted: 07/03/13 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Getting ready to figure out why my porch light and door handle light both stopped working at approx. the same time. I took at look at fuses, but don't see any that are obviously bad, but can pull each one and check them later.
The odd thing is (to me, at least), we have a switch, just inside the door that controls those lights. The switch itself has a small neon light in the switch. It is a push-to-make/push-to-break switch. We we push the switch, the neon light comes on, telling us the lights are on. I would ASSUME (yeah, I know...) that the small light in the switch is being powered by the same circuit that powers the lights, which means there's power to the circuit.
Any ideas? I don't see a fuse that's marked with anything that would make me think of the porch light....so not sure if it's possible they put that one under the hood?
Jim
2005 Pace Arrow 36D
Very Understanding Wife
1 Boxer ">
3 Maine Coon cats
JR45
Warren/OR/USA
Posted: 07/03/13 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Did you check the bulb. My light in the handle just went out, I have one on order.
JR
2006 Country Coach Inspire 360 40ft Genoa Designer Series Cat C9 Samsung 197 RR
Aluminum Radiator was recently replaced with a STEEL & COPPER Bolt Together Radiator w/ updated rubber mountings
SilverLeaf VMS 330
Toad--2011 Ford Edge Sport, Air Force One
enblethen
Moses Lake, WA
Posted: 07/03/13 10:30am Link  |  Quote  |  Print  |  Notify Moderator
My Pace Arrow also has a switch on the dash.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
2003 Chev Ice Road Tracker
SeaDog/BRR
Idaho
Posted: 07/03/13 11:24am Link  |  Quote  |  Print  |  Notify Moderator
If the lights are wired in series and one bulb goes out both stop working (like old fashion christmas lights) I would check the grounds. The lighted switch only indicates power to the switch, pull the switch and check the connections on the back of the switch.
Greg aka SeaDog Ret Navy
2016 Flagstaff 26 FKWS TT
96 Winnebago Adventurer 34RQ W/SO (selling)
06 F350 6.0, Harley Ultra Classic "> 64 corvette ">
JimM68
Yorkville, Illinois
Posted: 07/03/13 11:29am Link  |  Quote  |  Print  |  Notify Moderator
I agree. If the switch lights up, you have power, it is not a fuse.
Most likely an open wire, somewhere between the switch and the lights.
They will be wired in parallel, switched hot will go to one, and then on to the other. Problem could be either the hot or the ground side.
Jim M.
2008 Monaco Knight 40skq, moho #2
The "68"
My very own new forumfirstgens.com
My new blog
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
