RV.Net Open Roads Forum: Tech Issues: Tip on accessory for tank flushing
 > Tip on accessory for tank flushing
tkcas01
Roaming Fulltimer
Posted: 07/22/13 08:47am Link  |  Quote  |  Print  |  Notify Moderator
I was recently parked at a location where I needed to use a portable macerator for dumping holding tanks. Using that, after dumping the black tank you can turn the macerator off, open the grey dump valve and let that water back-flush into the black.
I found that cleaned out the black tank very thoroughly to the extent that the tank sensors started working after years of always showing full! I know those things are the curse of almost every RV owner. The macerator also has a connection for a water hose so you can backflush both tanks with fresh water.
Realizing the value of the backflush technique, I looked for a solution to do the same thing when using the slinky. Found this at Camping World and very happy with it. A good accessory for keeping tanks clean.
http://www.campingworld.com/shopping/item/flush-king/20522
Roaming Full Timer
2004 Monaco Diplomat DST
2007 Jeep Grand Cherokee Toad
LakeN
North Carolina
Posted: 07/22/13 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Have been using one for years....it is invaluable!!
lanerd
Home in Ridgecrest CA for the winter.
Posted: 07/22/13 10:09am Link  |  Quote  |  Print  |  Notify Moderator
Using the gray tank water to back flush the black tank is a common practice. You don't even have to turn off the macerator to do it.
Flush King has also been around for years and years and is a popular device. You can get a much cheaper knock-off at Walmart (just doesn't have the gate valve). I use both the macerator and the Walmart knock-off on my coach....but black tank sensors are still not reliable.
Thanks for the info.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
mlts22
Austin, Texas
Posted: 07/22/13 11:33am Link  |  Quote  |  Print  |  Notify Moderator
I use the cheap method. A Valterra twist-on gate valve so I can open/close the black/grey tanks without anything coming out. I then drain the black tank, and backflush it with the grey tank, just as I do with the macerator pump, except I just open/shut the additional valve instead of running the pump.
Old-Biscuit
Verde Valley
Posted: 07/22/13 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
I also went the cheap way but permanently.......
Installed a drain valve on horizontal run of drain line just before end cap.
No surprises when removing end cap
Don't have to store it like a twist on style (don't want twist on left hanging from end of pipe when traveling)
One of the first mods I do to all my trailers.
Gjac
Milford, CT
Posted: 07/23/13 08:29am Link  |  Quote  |  Print  |  Notify Moderator
I guess I use a cheap method too. I first dump the black tank, lift hose above the gray,open gray valve, let gray fill the black, raise and lower the hose to provide added flushing, then quickly insert hose into the dump hole.
Ron3rd
Upland, CA USA
Posted: 07/23/13 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
The Flush King is one of the best accessories I ever bought.
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
