RV.Net Open Roads Forum: Tech Issues: Atwood model 8531-Iv-dclp furnace
 > Atwood model 8531-Iv-dclp furnace
eq6352
Tn
Posted: 10/16/13 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
I have an Atwood 8531 furnance in my trailer and I just replaced the circuit board because it was bad. I am still not getting ignition when the unit comes on. What is the voltage supposed to be to the ignition probe? I am only getting between 7 and 9 volts. I am getting gas but it will not ignite.
wolfe10
Posted: 10/16/13 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
What is voltage where trailer wire goes into furnace?
Is the fan turning/air flowing-- assume so since gas valve is opening?
Brett Wolfe
2003 Alpine 38'
eq6352
Tn
Posted: 10/16/13 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
I have 12.6V coming to the control board. The fan is running and the air flow is good. The LED on the control board is green until it tries to ignite. Then it turns red during the ignition cycle.
Kirk
Livingston, Texas.
Posted: 10/16/13 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
I am wondering why you replaced the circuit board? If you are measuring the voltage to the spark probe when it fires very low as the service manual lists that as a "high tension" lead and does not specify a voltage but it is in the 1000V or so range. They do advice not to attempt to measure it.
I suggest that you download a copy of the service manual from the site of Bryant RV and study it.
Good travelin! ........Kirk
Professional Volunteer
Fulltimer for 11 years,
URL: www.adventure.1tree.net
Old-Biscuit
Verde Valley
Posted: 10/16/13 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
Electrode is out of adjustment
Electrode is faulty
Electrode high tension wire is bad
Bad or loose ground
I suspect your electrode is bad
Here is a service manual that covers your model......LINK
