RV.Net Open Roads Forum: Snowbirds: Ice/Snow on roof at departure time
Search only in Snowbirds
Open Roads Forum  >  Snowbirds
 > Ice/Snow on roof at departure time
tatest
Oklahoma Green Country
Posted: 11/03/13 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
golfknut wrote:
We will be towing our car......Has anyone ever had any damage done to their toad from snow/ice coming off their rig while towing?
That changes the picture, doesn't it. Depends on how thick the ice gets from freeze thaw, and sizes of chunks as it breaks up. Five to ten pound chunk inch or mor thick is going to do some damage, scratches and dents at least, if not enough speed differential to break a windshield. Towed vehicle, ice is going to hit it, rather than the pavement.
Tom Test
Itasca Spirit 29B
ScottnSherrie
Augusta, GA
Posted: 11/03/13 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Scrolled through the posts so sorry if I missed this suggestion. Get a tarp (or two spliced together) and cover the roof if the forecast calls for snow. Be sure to have several ropes tied to the eyelets. Before you leave, pull off the snow and ice laden tarp.
88 Gulf Stream 34' Sun Vista, Ford 460, Edelbrock Perfomer carb, Thorley headers
Ford F-250 crew cab 4X4, 6.0 turbo diesel
complete roof rebuild
daughter 19, son 16
US Army Desert Storm vets (both of us)
left: The Ol' Gal right: DW with White Lightnin'
SkiingSixPack
Minnesota
Posted: 11/03/13 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
I would not do this, no offense meant. This would be very likely to cause damage ...
I drive our motor home to and from skiing areas all winter and in most circumstances, there is not a problem. Semi drivers do not seem to climb up to get rid of the snow. Just part of driving in the winter... IMHO
IMHO
My better half
DS-18,DD-17,DS-15,DS-15 (4 teenagers, in da house)
Summit Red Sunshine-4
Brandy Red Sunshine-At the bridge
The greatest thing you ever can do now,
Is trade a smile with someone who's blue now,
It's very easy just...
ScottnSherrie
Augusta, GA
Posted: 11/03/13 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
No offense taken. Living in the land of one measurable snow every five years I have limited knowledge of how best to deal with snow.
trigley
Central Alberta
golfknut wrote:
We are taking our first snowbird trip this winter with a planned departure date of late December.
I was wondering how much roof melt-off of ice and snow there would be if I turned on the furnace and let the inside temperature get up into the 60's or so? Would there be any melting of roof snow at that temp?
We don't tow but sometimes use our unit for 4 or 5 days with snow cover. The snow does melt somewhat but does not disappear in that time frame. Exterior temperature would have a bearing.
I would be concerned heating the unit could create more ice if the temperature is below freezing when you do leave.
time2roll
Posted: 11/03/13 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
I thought some truck washes would de-ice the roof. Call around.
Otherwise I would melt it off with water if legally required.
I have had plenty of snow and ice build up while the trailer is in use and heated to 65-75. Used warm water to clear the slide. Roof melted on the road.
675w Solar pictures back up
roscoe
Priveledged resident of the gorgeous hudson valley
Posted: 11/03/13 10:49pm Link  |  Quote  |  Print  |  Notify Moderator
I always have the wife or MIL climb up and clean the ice or leaves off the roof. Just remind them to be careful.
SGTJOE
Utah
Posted: 11/04/13 12:18am Link  |  Quote  |  Print  |  Notify Moderator
Some of that "snow" can melt and build up some pretty thick heavy pieces of ice. I took my MH to a local truck stop that has a wash rack to clear the snow & ice. I'm sure in your area there is a truck wash that would do it. Better safe then sorry. Blowing snow isn't bad, but thick ice can penetrate a windshield at 55mph plus. You'll find that most States can and will ticket for this type of hazard. The fine may not be much, but how would you feel about causing a serious accident where someone could lose their life.
2001 Trade Winds 7390
Toad 03 Grand Am
almcc
Ontario, Canada
Posted: 11/04/13 05:59am Link  |  Quote  |  Print  |  Notify Moderator
I had a similar problem a couple of years ago - I left the slides out and it snowed. I ran the furnace and the snow melted a bit then turned to ice over the next night (insulation was too good!). I ended up running a hose from a hot water connection and using the hot water nozzle to melt the snow/ice, waited for some of the water to run off, then closed the slides before the water froze again.
It should work on a roof as well. Maybe you could try a pressure washer with hot water (and a "gentle" nozzle), might work quicker. For those of you in the north, don't forget to winterize the pressure washer after (don't ask me how I know!).
Dave Pete
Wyoming
Posted: 11/04/13 06:25am Link  |  Quote  |  Print  |  Notify Moderator
My experiences. Had a 3/4 ton truck with 8' pop up camper (now have a travel trailer). I live in Wyoming (and for three years in Fairbanks, AK).
In Wyoming usually the wind blows and where I parked/stored the camper the snow didn't stay long after a storm so not really an issue (excess weight etc.). But when on the truck and a Spring storm dropped heavy wet snow that didn't want to melt fast or blow off, it was a problem. Weight (very heavy snow) caused noticeable high-center of gravity. I didn't like that, or the concern of leaking from puddling under the snow. Carefully used a push broom from a step ladder alongside the camper. Helped some, but it was really stuck on (hydrostatic adhesion). But getting some off helped the weight issue. No damage that time.
Next in Fairbanks. The snow doesn't melt all winter. Maybe three feet high by spring. By spring I'm concerned about weight. Used broom and plastic snow shovel, gently! My roof was obstruction free except one vent cover. I knew about the cover, and exactly where it was. I clipped it both times (each spring) and had to replace it both times.
Lil' Queeny - 1968 Travel Queen
Big SAL-2006 Dodge Ram 2500
Tow Mater-1964 Road Runner 15' Canned Ham
Fairweather June-1957 Leisure Home 20'
No Name-2013 Komfort 2410RK 29'
Happy Trails to You.
