RV.Net Open Roads Forum: Tow Vehicles: Ike Gauntlet
Search only in Tow Vehicles
 > Ike Gauntlet
Taco
VA
Posted: 11/17/13 07:29am Link  |  Quote  |  Print  |  Notify Moderator
According to this site it struggled it lost speed and downshifted which the people on this site identify as the hallmark of a truck struggling on a grade.
Also it is a diesel and didn't go 65 mph up it in overdrive, I have been told over and over on this site that a diesel truck will go 65 up any hill in overdrive with the cruise on.
As far as the driver not knowing the truck, he held it to the floor the whole way, you would hope that the automatic transmission should be smart enough to know the driver wanted max effort.
LarryJM
NoVa
Posted: 11/17/13 08:14am Link  |  Quote  |  Print  |  Notify Moderator
That is REALLY BAD ASSUMPTION ... Programmed shift strategies are not designed to stay in gear up to basically the redline for power, but to shift for MPG reasons. When pulling a really hard grade I will get into direct and push this puppy up to 3K and keep it there if possible. I will never see 3K in any gear except OD and going way too fast to be towing regardless of grade.
Larry
RAINKAP INSTALL////ETERNABOND INSTALL
Turtle n Peeps
California
Posted: 11/17/13 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Larry
There is no programed shift strategies at WOT. That is why engines go into open loop at WOT. AT WOT it's all about power and engine and shift strategies are programed as such.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
FishOnOne
The Great State of Texas
Posted: 11/17/13 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
Here's the video of a RAM pulling up the Ike Gauntlet at a little over 50% of it's towing capacity and the F150 Eco Boost pulling up the Ike Gauntlet at a little over 100% of it's towing capacity.
RAM '13
F150 Eco Boost
Overall it appears the Ford Eco Boost is a strong performer with pulling at 100% of it's towing capacity while the 6.7 Cummins performance was less than spectacular!
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"Built Ford Tough"
'16 Sprinter 319MKS "Wide Body"
Turtle n Peeps
California
Posted: 11/17/13 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
RAM '13
F150 Eco Boost
ROTFLMAO, well I hope so! At a third of the load and almost the same HP it doesn't take a rocket surgeon to figure out who is going to be faster up the hill!
I saw a 600 HP class 8 Pete struggle up a hill the other day because he was down to less than 30 MPH. [emoticon]
crabbin cabin
on the road
Posted: 11/17/13 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
So - what, where is this so-called gauntlet??
crabbin cabin
on the road
Posted: 11/17/13 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
OK - just watched the video! Wrong, wrong going from Silverthorne CO(my former home for 13+ years), in Summit county, eastbound on I 70 you approach and go thru' the Johnson Tunnel!!
The Eisenhower Tunnel is westbound only and was completed several years before the Johnson!
EcoBullet
SE Oklahoma
Posted: 11/17/13 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
When I clicked on FishOnOne's F150 Eco Boost link, my computer shutdown. Something's fishy.
Me 1954, Nana 1954, Grandson 2003, Granddaughters 2005 & 2008
2014 Keystone Bullet Premier 22RBPR
2013 F-150 XLT Supercrew 4X4 Ecoboost Max Tow
john&bet
North Vernon,in.
Posted: 11/17/13 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
If your talking about the I-70 Ike, I had no problem with it with my rig a few years ago. It down shifted like it should, I forget the exact mph and rpm now, but I passed an older Chevy 3+3 crew cab with a slide in camper and a small tow behind trailer. I assume it had 454 gasser so not surprised. Tranny didn't get hot nor did the engine. I was right at 19,700# combined weight. I am a happy RVer.
2004.5 Dodge 2500ctd Quadcab. Lariamie, 3.73, auto. pure stock
2018 Grand Design 337RLS
skyhammer
NW CA
Posted: 11/17/13 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
The Dodge sounds loud and I am surprised that it doesn't have a gear indicator.
2011 Host Everest, 11.5',triple slide.
2011 F-350,DRW,CC,LWB,4X4,6.7
 > Ike Gauntlet
