RV.Net Open Roads Forum: 2014 Cherokee - connect tow bar at tow hooks ?
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  Tow Bars
 > 2014 Cherokee - connect tow bar at tow hooks ?
sealg
Colorado
Posted: 12/21/13 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
The new 2014 Cherokee (Trailhawk model) tow hooks are pretty rugged.
Seems I could "modify/replace" the hooks to provide a place to connect my Blue Ox tow bar.
In other words -- no baseplate. That would be helpful since there ARE NO baseplates !
Whatchathink ?
sch911
Rochester Hills, MI
Posted: 12/21/13 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
No that's a bad idea. The baseplates are coming be patient. There are a couple of members here already testing them.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2007 Jeep Grand Cherokee Limited Toad
Jagtech
Sunny Southern Alberta, Canada
Posted: 12/21/13 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
The tow hook mounts should certainly be adequate to provide an attachment point. If they aren't strong enough to tow the Jeep with a chain, then they shouldn't be there. I wouldn't be afraid to use them, as long as you use good grade 8 bolts, double nutted. And any brackets that need modifying or welding should be done by a licensed welder. Also, the tow bar should be kept level, same height at the hitch and the Jeep.
1998 Triple E F53
1995 Jeep Wrangler toad
j-d
Sunny Florida USA
Posted: 12/22/13 05:39am Link  |  Quote  |  Print  |  Notify Moderator
Disagree. There's a Big Difference between "pull me out of this sand once" and "tow me thousands of miles."
I helped a neighbor install a Blue Ox "baseplate" onto a Hummer. Whichever model the smaller one, gussied-up Blazer was. Although the attaching points worked off of the tow hook bases, it included extra brackets and bolts that went behind those bases, and required drilling.
An OP here has already had one fabbed by DEMCO. BlueOx and RM can't be far behind. If they're behind at all. Have you called the companies?
If God's Your Co-Pilot Move Over, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100 218" WB
FANC 1
Rhode Island
Posted: 12/22/13 08:33am Link  |  Quote  |  Print  |  Notify Moderator
I would hope they design a base plate around the tow hooks and leave them on. That way you can go off road and on road.
tatest
Oklahoma Green Country
Posted: 12/22/13 10:38pm Link  |  Quote  |  Print  |  Notify Moderator
BlueOx mounted a baseplate at one time on the tow hooks of either a Ranger or Explorer, and learned the hard way that the tow hook mounting points were not strong enough to handle the bending loads at that point coming from vertical loads towbar to baseplate. These come from acceleration, braking, traversing bumps and dips.
Tow hooks might work for flexible connections, cable or chain, but that won't brake the toad for you, or let you push back. There is also sometimes a situation that those hooks are basically cosmetic, rather than functional, like "fog lights" not really designed for use in fog.
Not all tow hook mounting points may be inadequate, but the requirements are different enough that we can't simply assume that if the hooks are good for a pull they are good for towbar loads.
Tom Test
Itasca Spirit 29B
Hank MI
Brighton, Michigan
Posted: 12/23/13 06:19am Link  |  Quote  |  Print  |  Notify Moderator
They're recovery hooks, not tow hooks. As jd said, designed to assist when stuck in snow, mud, sand, not for towing the vehicle down the road.
FIRE UP
Lake Havasu City AZ
Posted: 12/23/13 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Well Gang,
I'm not sure of just how sturdy the steel or, frame design or, mounting system in general is for the tow hooks on that Cherokee but, the Blue Ox base plate(s), yes PLATES, are direct replacements for the tow hooks on our present toad, a 2011 GMC Sierra 1500 4x4 Extended Cab. All I had to do to install them was drill one extra hole per side and then, install two long bolts w/nylox nuts per base plate, right through the frame.
It's a very sturdy system and, I've checked it constantly while towing and there is absolutely no evidence of weakening or, stress, or deterioration of the strength in any manor. Now, again, this is our truck and, not a 2014 Cherokee. So, I cannot vouch for the strength in that kind of system, on that kind of vehicle. If it were mine, I'd take a good look at the system to see if it would/could work.
But, I'd sure as heck do whatever re-enforcements needed to make it work, if I was going to do it that way. Good luck
Scott
Scott and Karla
SDFD RETIRED
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
DiamondDan
IL
Posted: 12/23/13 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Roadmaster has their baseplates up for the trailhawk models, and the installation appears to require the removal of the tow hooks.
rr2254545
Central Minnesota
Posted: 12/24/13 09:30am Link  |  Quote  |  Print  |  Notify Moderator
Whatchathink ?
I saw the Demco setup for my Limited after they engineered it. I was amazed at how much metal was on it. I can not imagine that the red hooks are so well secured.
Link to Demco - the black one is mine
https://dl.dropboxusercontent.com/u/50497884/Base_Plate_Demco_2014_Cherokee.pdf
2012 Winnebago Journey 36M Cummins 360
2014 Jeep Cherokee Limited, Air Force One, Blue Ox Avail tow bar
308 Campgrounds,70K miles driven in our motor homes and 1496 nights camping since we retired in July 2009 - 48 States and 35 National Parks
