RV.Net Open Roads Forum: Class C Motorhomes: Battery replacement
 > Battery replacement
Cruisineasy
Hayward
Posted: 01/10/14 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2011 Jayco Greyhawk 31DS.
The chassis battery is almost toast. Other then resetting the stereo presets will anything else go south when I disconnect the old battery and install the new??? I wouldn't think so, but thought I'd check..
SCVJeff
Santa Clarita, CA.
Posted: 01/10/14 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
Possibly the engine and trans CPU. I just found out 15 mins ago that when you pull the chassis the battery the whatever engine parameters are used for smog checks are erased and the vehicle needs to be driven to accumulate enough data for an accurate measurement again.
Jeff - WA6EQU
Cruisineasy
Hayward
Posted: 01/10/14 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
So it's kinda like clearing error codes. It has to be driven a while to let all the sensors fire.. That's fine. I'm gonna replace the battery tomorrow and take it camping for the weekend. Should be about 200 miles there and back. That ought to set it all straight.....
Thanks
j-d
Sunny Florida USA
Posted: 01/10/14 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
If you have the Ford Chassis Owner Manual, check there for battery replacement guidance. I think you're safe simply disconnecting, changing battery, reconnecting. Used to be the Radio had a Security Code and if you couldn't re-enter it, the radio would no longer work, and anti-theft measure. I don't think that's common anymore.
There's a "memory saver" which is essentially a little 9V battery that you clip to the battery cables before disconnecting. It's supposed to save things like Clock, Radio Stations, and Driving Patterns. But some owner manuals contain specific wording to NOT use one.
If God's Your Co-Pilot Move Over, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100 218" WB
time2roll
Posted: 01/10/14 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
2011.... any warranty? Seems like an early death.
How do you keep the battery charged between trips or while camped?
I think you can use a 9 to 12v battery to keep the memory from deleting.
675w Solar pictures back up
Cruisineasy
Hayward
Posted: 01/10/14 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
I run the gen and the engine every two weeks..
Worked for over two years
tatest
Oklahoma Green Country
Posted: 01/10/14 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Relaced my 2003 vintage OEM battery in 2008. Engine - transmission computer will rest to defaults, had to relearn my driving style, shifts were back to "normal" after first 100 mile trip. Not sure what happens with keyless entry, if you have that.
Did not have radio issues, have aftermarket radio which I disconnect anyway, don't use any presets. Radio house-chassis switch to house, the house batteries disconnected. Some radios on battery in storage will pull it down pretty fast, and in a way that damages lead acid batteries permanently, way below a normal voltage for "complete" discharge. Engine control unit can also do that, takes longer.
Tom Test
Itasca Spirit 29B
time2roll
Posted: 01/10/14 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
This is where I think 100w of solar on the house battery and a Trik-L-Start combiner to keep the chassis battery charged would be less wear on the engines and add life to all batteries.
(assumes the roof gets at least occasional sun)
pianotuna
Regina, SK, Canada
Posted: 01/10/14 10:35pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
You might find that if you added the solar and the trik-l-start that the chassis battery may come back to useful life.
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
Cruisineasy
Hayward
Posted: 01/14/14 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
Success!!! Just changed it out with no problem..
Since I don't set up the stereo with presets, would it mess things up if I rigged a disconnect for the chassis battery???
