RV.Net Open Roads Forum: Tech Issues: Opinion on solar panel kit wanted
 > Opinion on solar panel kit wanted
tenbear
Northern Vermont, USA
Posted: 01/19/14 05:31am Link  |  Quote  |  Print  |  Notify Moderator
I received a notice of this solar panel kit. It seemed like a good deal here in the northeast. 300 watts for $500 including S&H.
All opinions welcome.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
WoodGlue
Los Angeles / Montana
Posted: 01/19/14 05:36am Link  |  Quote  |  Print  |  Notify Moderator
At more that $1.00 per watt, seems awfully expensive. Also, you might want to upgrade the controller to 30amp in case you ever want larger panels.
WoodGlue
pianotuna
Regina, SK, Canada
Posted: 01/19/14 05:49am Link  |  Quote  |  Print  |  Notify Moderator
Hi tenbear,
Looks good to me. I'd probably upgrade the controller to something that allows a temperature probe on the battery.
If you have a good roof location with zero shading I'd consider using mppt technology and wiring in series--of course this costs more.
* This post was edited 01/19/14 06:16am by pianotuna *
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
RJsfishin
Winston Or.
Posted: 01/19/14 06:48am Link  |  Quote  |  Print  |  Notify Moderator
W/ solar running near $1 a watt, and a $15 controller, how is that a good deal at $500 ?
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KingDome/sat, 2 Oly Cat heaters, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
pianotuna
Regina, SK, Canada
Posted: 01/19/14 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Hi RJ,
It is under $2 per watt. Please show us your source for $1 per watt with hardware, controller and wire?
tenbear
Posted: 01/19/14 07:49am Link  |  Quote  |  Print  |  Notify Moderator
I have been unable to find solar panels at $1 a watt in the north east. Buying panels from the south west where the best deals are gets expensive due to the shipping cost. Maybe I should look harder.
tenbear
Posted: 01/19/14 07:53am Link  |  Quote  |  Print  |  Notify Moderator
And shipping.
pianotuna wrote:
Hi RJ,
CA Traveler
The Western States
Posted: 01/19/14 07:57am Link  |  Quote  |  Print  |  Notify Moderator
For 300W including wiring, hardware, controller and SH that is a good price.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
750 Watts Solar MPPT 60 Controller
2004 CR-V and 2014 Grand Cherokee
Bob
BFL13
Victoria, BC
Posted: 01/19/14 08:28am Link  |  Quote  |  Print  |  Notify Moderator
The usual rule for PWM is you need 20% margin over your rated Isc amps for sizing the controller and the fuse that goes on the pos line near the battery.
300w pointed at a high sun can get you 300/130 x 8.2 = 19a (which should be about twice the Isc of a 150w panel) so the 20a controller supplied is inadequate for amps size.
Also that controller has been noted on this forum in other kits as a poor one for some reason can't remember so you will need a better controller anyway. Lots of 25 and 30a PWM controllers on ebay at low cost, so no problem there.
As to that kit's price, just take off the "free" shipping and go with what they really cost and it looks better.
An alternative to consider is a single 24v panel in the 250w range and the 20a Eco-worthy ($102) or Tracer $130) MPPT controller.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Almot
out there
Posted: 01/19/14 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Don't know where BFL got his 130 in that formula, but 19A total Isc is really too close to the rated 20A PWM limit. For 300W array I would go for 25A controller.
The price - to me this kit has only one useful item: 2*150w panel. Possibly, 2*MC4 Y-connectors, they are expensive but you only need them if you run a parallel without a roof junction box. Everything else is either wrong item or wrong quantity. 40ft #10 wire is too short for on-rig installations, this is mere 20ft one way run. Z-brackets are a cr-p. Controller is too weak for this setup. And yes, there was a negative feedback on Phocos 30 - which in itself doesn't mean much, but the brand is not popular in RV.
