RV.Net Open Roads Forum: Ford 4x4 2002 explorer will not go into 4 wheel drive
 > Ford 4x4 2002 explorer will not go into 4 wheel drive
jackwmssr
Blue Springs Mo. USA
Posted: 02/03/14 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
I think I need the help of a Ford mechanic. My 2002 ford explorer 4.0 v6 automatic will not shift into any 4x4 positions. I have checked all the fuses that I can find, 1 under the dash and 2 under the hood. It does not make any sounds at all when I push the 4x4 buttons. It did not make any strange sounds the last I used it a few weeks ago. I have tried it moving and sitting still, in neutral with the brake on. I have had it since new and used it every winter so I am sure it is not operator error. It has 99000 miles on it. Now for a little recent history. I had the cables disconnected to clean the post 3 weeks ago. Two days later I used a homeowner style alternator tester to check the alternator (good). I jumped the MH last week to start it, all of these since the last time used the 4x4. While doing the above I never did hook any thing up wrong. THE FORECAST IS CALLING FOR SNOW tonight 7 to 9 inches. I would be very thankful if some one can help me with this.
Jackwmssr
2000 Georgie Boy,Cruise Air
2002 Explorer toad
TNRIVERSIDE
East Tennessee
Posted: 02/03/14 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like you have tried the most likely. I have had a Ford that had the shift linkage that got out of adjustment and the 4X4 would not sift. I found that if I positioned the shift leaver a little off neutral but not fully into D or R it would shift. Its worth a try. Good luck.
2014 Coleman CTS192RD. 2009 F150 4X4, 5.4, 3.31
Jeff
dlk
Michigan
Posted: 02/03/14 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
First off is it the shift on the fly 4x4, if it is you can try this, don't ask me how I know. On the transfer case, drivers side is an electronic servo motor that shifts the unit from 4 hi or low, mine used to not work at times, I took a rubber mallet and gave it a couple of whacks and guess what it worked again, your out nothing but a few minutes of time to see if it works.
Dan & Pam UP of Michigan
F 350 Fx4 Keystone Sprinter
Turbo Diesel Dude
Ocala,Fl
Posted: 02/03/14 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
I'd go with dlk. Quite possibly the shaft on the electric servo motor may be frozen/rusty or a wire is broken.
charles weidman
Sloop Smitten
San Marcos, CA
Posted: 02/03/14 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
What Dan indicated is a well known problem with the transfer case shift servo. It rotates to the end of play where they installed nylon bushings that get crushed over time. When that happens the servo loses its place and you have to remove it and reposition the internal components. If you do a search on any of the online Explorer forums they have it pretty well documented. I had to do it on my old Explorer as well. You might check the plug at the servo as well and make sure it has not been damaged or disconnected.
1992 Fleetwood Jamboree Rallye 24' M/H
Ford E350 Chassis, 7.5L Engine, E40D Transmission
My other motorhome is a 1978 Catalina 25 Sailboat
Cruising Califonia, Sailing the Pacific!
nettech207
kennewick, wa
Posted: 02/03/14 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
you might have a clog vacuum line ford shift on the fly used vacuum hoses to switch between 2 and 2 wheel drive, or the electronic shift module could be bad. I would bring it to a ford guy he should be able to pinpoint the problem pretty quickly
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 02/04/14 11:55am Link  |  Quote  |  Print  |  Notify Moderator
Kudos for a IMHO a 5-Star response.
Sloop Smitten
San Marcos, CA
Posted: 02/04/14 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Mex!
tenbear
Northern Vermont, USA
Posted: 02/04/14 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
My '06 Ranger had the same problem. Ford replaced some motor under warranty and that fixed it. I have no idea where the motor is, probably the same motor dlk mentioned.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
Okie1
Oklahoma
Posted: 02/04/14 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
Same here, It seems like the key is to put it in four wheel drive every couple of weeks to keep everything free. A slight tap has worked for me several times....
2016 F-350 four door Lariat 4X4 long bed & 2012 Sabre 34RLQS...
