RV.Net Open Roads Forum: Class A Motorhomes: Vinyl Covering Coming Loose from Dash
 > Vinyl Covering Coming Loose from Dash
mfox20
Fort Worth, TX
Posted: 02/13/14 11:21am Link  |  Quote  |  Print  |  Notify Moderator
The vinyl covering is coming loose on my 2000 HR Endeavor (gas model).
I suspect it has shrunk due to the high heat here in Texas. It is mostly loose on the front of the dash facing the the driver and passenger areas, below the instrument panel, radio, heater controls and below the glove box area.
I have tried using 3M spray adhesive with not much success due to the shrinkage of material. Just wants to pull away again.
I am sure lots of you have or had this issue on older rigs. Anyone successfully made this repair?
I am thinking I will need to remove the entire covering and start over. Need any insight you have had in the this repair including what adhesive you used.
Thanks,
Michael
Michael
2000 Holiday Rambler Endeavor Gasser
2013 Honda CR-V Toad
Johno02
Lexington, TN USA
Posted: 02/13/14 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
This is a common problem with older vehicles and padded dashes. As you suspect, heat and sunlight makes the vinyl shrink and get hard. Check with someone that does auto and truck restoration.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 wife, 1 dog(?)
teddychamp
Posted: 02/13/14 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
I would recommend a Dash cover and not bother with repair. Go to Dash covers by Josie on the Internet.
Fleetwood Bounder 39R 330hp Cummins Turbo Diesel
Freightliner Chasis
Ford Escape Limited - on ACME Towdolly
mfox20
Fort Worth, TX
Posted: 02/13/14 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies but neither address my original post. The top of the dash where you would put a cover is in great condition. The portion just in front of your knees is my problem area. This dash area is not padded, the vinyl is glued straight to the fiberglass dash.
Thanks and hopefully someone has dealt with this issue.
Michael
