RV.Net Open Roads Forum: Tech Issues: Bathroom Cabinet Latch
 > Bathroom Cabinet Latch
DD716TED
Washington State
Posted: 02/28/14 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
The medicine cabinet in the rear bathroom of our tt has a magnet type latch on it that when traveling, always lets the door open.. I am tired of the DW using Duct Tape to keep it closed every time we move the trailer.. Has anyone else had this problem? Is there a better replacement latch or something to keep the door closed when traveling?
pchartrand
Michigan
Posted: 02/28/14 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
Try just adding an additional magnet kit, it might be just enough to keep it closed.
2014 Keystone Bullet Premier 22RBPR
2017 Chevy Colorado (Duramax)
myredracer
Langley B.C.
Posted: 02/28/14 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
Have you tried bungee cords? [emoticon] We had to do that on our pantry door in our rear kitchen... [emoticon]
Actually, there is a heavy duty latch here: cabinet latch Have not seen it in person, but at $10 per each, it must be good. I'm going to try one on our pantry door.
Those magnetic catches are rather weak to start with. We wanted to use them in place of the "standard" ones used like BFL13 has in his link on our new TT. The dealer was going to replace them all for us on doors and drawers but they found they were far too weak so we left them alone. For a small medicine cab. door it should be fine.
* This post was last edited 02/28/14 09:33pm by myredracer *   View edit history
Used to be I couldn't even spell RV, now we own one!
Gil, Deb & Dougal the Springer Spaniel
2014 KZ Spree 262RKS, many mods (mild to wild), Reese DC WDH
2009 F250 super duty, V10, supercab, 4WD, 8' bed, Hawkshead TPMS & T-valves
BFL13
Victoria, BC
Posted: 02/28/14 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
I did have to change the passage way door catch to a magnet type, because every time we parked and levelled the trailer, the stupid door/doorway latch parts would not line up right. A magnet with a wide plate works every time.
A cabinet door is so small, a twist in the trailer when parked should not be an issue, so you could use the latches all our cabinets have;
https://www.google.ca/search?q=cabinet+l........s.com%252Flatches_700.html%3B1100%3B1100
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Gdetrailer
PA
Posted: 03/01/14 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Wow, a lot of off the wall ideas for a simple problem [emoticon] .
The REAL way is to use a ROLLER "CATCH" (the item you are looking for is called a catch, not a latch).
YOU CAN FIND HERE
Guaranteed to NEVER, EVER fly open again...
Be prepared, they might be small but they pack a huge holding power punch (make sure your face is not close to your arm when opening [emoticon] )!
That type of catch was used in my Dad's 1960's truck camper and we never had a door open ever.
Solved all my door latch problems.. I used them in both of my TT rebuilds with success.
Cheap also at under $1 each! [emoticon]
bluka43
Southern Louisiana
Posted: 03/04/14 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
You might want to look at my remedy which is posted in the Do It Yourself Modifications section of the forum and it listed as Keeping cabinets and drawers locked while traveling. Found these at Babies R Us.
Kenny
