RV.Net Open Roads Forum: Travel Trailers: Andersen-3604 Camper Leveler
 > Andersen-3604 Camper Leveler
Page of 9
KS56
Western NY
Posted: 03/23/14 11:13am Link  |  Quote  |  Print  |  Notify Moderator
Just stumbled upon the 'Andersen-3604 Camper Leveler' while searching for an easier way to level my travel trailer. Sounds like a brilliant way for side to side leveling.
Not happy with the plastic 'lego' type blocks that I am presently using. I'm on my second 10 block set and they keep on breaking!
Any comments on the Andersen-3604 Camper Leveler from someone that is familiar with them would be greatly appreciated.
canadiankid
Langley BC Canada
Posted: 03/23/14 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
Here are some reviews from amazon. They look pretty cool. Hope this helps.
2010 Tundra Crewmax 2WD 5.7
2009 Greywolf 22BH
JJensen79
Michigan
Posted: 03/23/14 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
I have these for our camper and it is a world of difference with leveling. They are as easy as they say. I get the trailer close, put them under the tires, back up a little more than level, put the included chocks in, and pull forward a little bit.
I have used them on grass, soft dirt, gravel(didn't even put a mark in them) and have not had one problem with them sinking or anything else.
Our current method is to have the wife stand on the side while I back on the levelers, similar to the video. I would like to put one of those fifth wheel levels on the front of our camper, but because it has a curved front, I am not sure how to mount it.
I know they are pretty pricey, but well worth the time it saves, especially when the kids are screaming.
KS56
Western NY
Posted: 03/23/14 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you kindly for the response.
I was hoping for some positive responses. Just ordered two sets (dual axles). I have a huge bubble level that I will mount at the front of my new travel trailer that can be seen from inside the tow vehicle. Should be a great setup. Now if the weather would only cooperate......
JJensen79
Michigan
Posted: 03/23/14 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
You'll have to send me a pic of your level once you get it mounted. I think that would make it so much easier.
KS56
Western NY
Posted: 03/23/14 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
I will try to post a picture once I get it mounted.
http://www.amazon.com/gp/product/B000EDUTOA/ref=oh_details_o08_s00_i00?ie=UTF8&psc=1
fla-gypsy
North Florida
Posted: 03/23/14 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
Nice concept
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
rider997
California
Posted: 03/24/14 12:40am Link  |  Quote  |  Print  |  Notify Moderator
They're just as good - no, better - than the ads would have you believe. It takes under 30 seconds to level the trailer as long as you don't need to exceed the 4" maximum of the cams. They're also built very well (in the USA) and appear that they'll last quite some time.
LarryJM
NoVa
Posted: 03/24/14 01:26am Link  |  Quote  |  Print  |  Notify Moderator
How in the world are you breaking those lynx leveler blocks ... I have three sets that I use to make ramps for my 1T Van and can't envision how they woould break. Personally, I don't like the concept of the small amount of ground contact with that Anderson system since the PSI at "ground contact" has to be MAGNITUDES larger than something like the Lynx levelers and they would sink like a rock on soft ground.
Larry
RAINKAP INSTALL////ETERNABOND INSTALL
Mickeyfan0805
SE Wisconsin
Posted: 03/24/14 04:52am Link  |  Quote  |  Print  |  Notify Moderator
Larry
I don't see it that way. While I don't have them, it appears that, once the chock is placed under beveled leveler, you not only have the portion of the leveler, but the entire chock block handling your pressure at the ground - and that chock alone looks as big, if not bigger, than a Lynx brick.
Meanwhile, have you looked at how much actual surface area of a Lynx brick hits the ground? About 90% of the size of the brick is air. It is only a very small portion that touches the ground and actually bares the weights of the vehicle.
Don't get me wrong, I use Lynx Levelers with absolutely no issues, but I don't see them as any better, in 'pressure at ground level,' than this Andersen system.
Honestly, my greater concern would be slippage. The force placed on typical boards and blocks in almost entirely vertical - meaning the weight of the trailer is actually driving the leveling device more firmly into the ground. This system, however, seems to transfer some of that weight into a lateral force (the curved side of the leveler has some force that would be trying to push the chock away). While it clearly isn't a common problem, my initial thought is that, in the right situation, this could cause the chock to slip out from under the leveler and create a stability problem.
Page of 9
