RV.Net Open Roads Forum: May have just destroyed my TV engine:-(
Search only in Tow Vehicles
 > May have just destroyed my TV engine :-(
Page of 19
TucsonJim
Tucson, AZ, USA
Posted: 03/30/14 10:33pm Link  |  Print  |  Notify Moderator
I made a stupid and likely very costly error this afternoon. I have a 2013 Ford 6.7 Diesel. About a week ago, I needed to top of the Diesel Exhaust fluid before a long trip. I bought a 2.5 Gallon container and poured it into the DEF port. However, there were still 3-4 cups of DEF in the container and the truck was full.
I put the remainder in the garage and took our trip. I put on about 500 miles this week, so this afternoon, I though I'd put the rest of the DEF in the truck. I have NO idea why I did it, but I opened up the diesel cap and poured the remainder of the DEF in the diesel fuel. I didn't realize what I'd done until I'd driven about 4 miles and the "Water in Fuel" light came on. It dawned on me what I'd done.
After researching many forums, in all likelihood the engine is now toast, and the cost will be somewhere around $10-12K to get it fixed. I'm sick to my stomach from the guilt this is causing. In addition, we have a big family camping outing on april the 9th that I'm likely going to have to cancel because I won't have a TV to pull the fiver to it.
I'm sick, sick, sick of the stupid error I made.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
SWD
Land of Living Skies
Posted: 03/30/14 10:39pm Link  |  Print  |  Notify Moderator
http://www.transliquidtechnologies.com/blog/bid/103155/What-happens-if-you-put-Diesel-Exhaust-Fluid-in-your-diesel-tank
The Mad Norsky
Yankton, South Dakota
Possibly not ruined. To me, with the amount you said you poured in, it is possible you just hit the threshold amount to activate your water in fuel light. My manual says when this happens you should stop ASAP and drain the frame mounted filter below the drivers seat.
Since your Water in fuel light came on, drain everything (frame mounted filter and the fuel tank), change both fuel filters and see what happens first.
Its worth a try.
Gosh, best of luck. If you're like me, and sounds the same, I'd be sick to my stomach too.
ON EDIT: thinking, and if this were me, I'd also add a good dose of lubricity additive to the fuel tank when refilling it. Maybe even higher dosage than is actually required for the amount of fuel in the tank.
And I'd surely use the good old PM-22-A from Ford itself.
Mind you, Stanadyne, Schaeffers Diesel Treat 2000, and even the good old Power Service are good lubricity additives. But in this case, I'd stay with the Ford/Motorcraft product.
* This post was last edited 03/30/14 11:12pm by The Mad Norsky *   View edit history
The Mad Norsky, Doll, Logan and Rocky
2014 Ram 3500 w/ Cummins/Aisin
2003 Hitchhiker Discover America Quad Slide
2016 Lance 1172 Torklift, FastGuns, StableLoads
RV'ing since 1991
I took the road less traveled .....Now I'm Lost!
tsetsaf
On the Road
Posted: 03/30/14 11:06pm Link  |  Print  |  Notify Moderator
I was not aware that the result could be so bad. If it is can anyone tell me why the filler necks are adjacent to one another. Hopefully you can fix it without the big price tag.
2006 Ram 3500
2014 Open Range
"I don't trust my own advise!"
The Mad Norsky
Posted: 03/30/14 11:10pm Link  |  Print  |  Notify Moderator
Both Dodge Ram and Ford build them this way, with the filler caps next to each other.
The high pressure fuel pump (a Bosch CP 4.2) used in the Ford is really, and I mean REALLY, particular and sensitive to water in the fuel. The fuel itself is ALL that furnishes lubrication for this pump.
Appears the 2015 Ford's are coming out with a newer model of this very pump, supposedly not as sensitive to water.
Turtle n Peeps
California
Posted: 03/30/14 11:25pm Link  |  Print  |  Notify Moderator
I have good news and bad news for you.
The good:
Almost assuredly you did not destroy your engine. If you did it would be around 20 grand to fix.
The bad:
You might have hurt or destroyed your fuel system.
If so, it will cost you about 12K to fix.
If it was my engine I would personally pull and put a new pump on before it took out the entire fuel system.
You can pay about 4 grand now or maybe 12 grand latter. Your choice.
Sorry about your problems.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
TucsonJim
Tucson, AZ, USA
It's not just the water in the fuel. The urea in DEF is very corrosive and destroys items that weren't designed for it such as fuel systems. It forms a white crystal structure that plugs up the system and destroys major components.
From what I understand, the injectors, fuel rails, filters, water separator and other components must be replaced. The fuel tanks and lines have be completely flushed and might need replacing. It doesn't matter whether it was one cup or 5 gallons of DEF. I'll post more tomorrow after talking to the dealer.
path1
Varies with weather
Posted: 03/30/14 11:36pm Link  |  Print  |  Notify Moderator
Maybe not as bad as you think. I doubt if local dealer can help with this question but Spend some time trying to talk with somebody at Ford maybe in tech dept or chemical engineer.
I made the mistake (one time) of putting some gas (about 2 gallon) in my diesel tank (capacity of 33 gal). Called my brother in law to find out if knew anybody with any brains about gas in diesel. He drives tanker truck for big company. He called their "formulation" guy. About 45 min later called me back that ratio of gas to diesel was not good, but OK to drive and at 3/4 tank refill to get ratio lowered. And keep refilling at 3/4 for about 1,000 miles. I know your talking DEF, but wanted to relay might not as bad as you think. Let's hope.
TucsonJim
Tucson, AZ, USA
Posted: 03/30/14 11:37pm Link  |  Print  |  Notify Moderator
I'm calling the dealer in the morning and I'll get it towed before turning the key on again. I might be lucky with just fuel system damage. I'll keep you all posted.
ksss
Eastern Idaho
Posted: 03/30/14 11:43pm Link  |  Print  |  Notify Moderator
Hopefully the filter caught all of the DEF. Man I feel sorry for you. If the worst has happened, it appears that some have had success filling an insurance claim. Might be a long shot, but it would certainly be worth looking into if it comes to that. Keep us updated.
The topic of having both the fuel and DEF next each other comes up every so often. Usually with some stating that it is nearly impossible to put DEF in the fuel tank even though they are side by side (considering how many of these you read and hear about, it's apparently more common than one would think). I don't have a pickup that needs DEF, but I do have employees. I really would be ok with having to open the hood to add DEF.
2006 GMC 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2015 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
Page of 19
