RV.Net Open Roads Forum: Tow Vehicles: "COKED UP"
Search only in Tow Vehicles
 > "COKED UP"
Page of 5
blkdodge
Arizona
Posted: 10/30/14 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone ever hear of a turbo getting ("coked up" dealer term)?
I lost a lot of power and massive drop in MPG while towing to Co.
Took truck 2012 3500 drw dodge to dealer and they had it for 3 days.
They say they flushed the turbo and it runs fine now.
How can this be prevented in the future and what causes this issue?
Any thoughts?
2012 Dodge 3500 DRW/2012 Heartland Landmark San Antonio.
darsben
Central and Northern NY/ Casa Grande, AZ
Posted: 10/30/14 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Coked up EGR valve
Coke = carbon
decnt article here
* This post was edited 10/30/14 01:55pm by darsben *
Traveling with my best friend my wife!
Bedlam
PNW
Posted: 10/30/14 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
Excessive idling, long periods of slow speed driving or over fueling the engine will cause coking of the turbine. If the oil was cooked, it is due to running the turbo hard and shutting down before the circulating oil has a chance to cool down the turbo. What oil is left in the turbo gets overheated and breaks down.
This was something I warned about with my variable geometry turbo on the 6.0 PSD. I tried to avoid the above conditions and never had problems.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
2oldman
Salton Sea
Posted: 10/30/14 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Google or Youtube: coking turbo
Be thankful you found an honest shop that didn't sell you a new turbo.
donn0128
Pronounced Ore-gun
Yup! Common problem. Run with the EB on all the time, dont lug the motor, dont drive in town traffic without getting it on the highway and driving it hard for 20-30 miles every week.
Either that or do the delets, which of course the federal government deemed illegal.
spoon059
Just north of D.C.
Posted: 10/30/14 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
Hilarious picture, from Chapelle Show. That's more referring to dry ashy lips that are burnt from a crack pipe.
Sounds like an honest mechanic, lucky you. This is the downfall of diesel vehicles for daily drivers with relatively short commutes. Glad you got it fixe, hopefully it was inexpensive for you.
I had an old GM 3.2 motor that had a problem with carbon buildup on oil drain lines somewhere in the engine. Oil couldn't properly drain back and would burn off and I would be short about a quart and a half between oil changes.
The suggested fix by other owners of the same engine was to use Seafoam in the oil before changes and suck up some Seafoam in the brake booster. Something in the Seafoam was good at breaking down the carbon buildup and freeing up those passages. Don't know how it worked... but it worked. No more oil being burned.
Not sure if there is some similar tip for you. Find a Cummins forum and see if anyone has suggestions. Good luck!
2015 Ram CTD
2015 Jayco 29QBS
blkdodge
Arizona
Posted: 10/30/14 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
The dealer didn't charge for it because it fell under the 100k warranty. I do a lot of stop and go driving every day. Freeways here suck. 1.5 hours to drive 37 miles. So I guess there really isn't anything I can do to prevent this, except park it. [emoticon]
downtheroad
Pacific Northwest
Posted: 10/30/14 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
Only Dodges have this problem.....
Seriously, good explanation here from Bedlam.
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
ChooChooMan74
Tiverton, RI
Posted: 10/30/14 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
I didn't know dodge made trucks any longer...
In all seriousness, do you idle your truck before shutting it? Oil coking in the turbo is bad. My diesel tech is adamant about it. I wait to my pre turbo EGTs is below 300.
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
donn0128
Pronounced Ore-gun
Posted: 10/30/14 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
Actually from the picture it is not coking but rather soot inside the turbo. This is common of a truck that is used as a commuter car and not used as a work tool. Which is exactly what the OP is doing.
To the OP, You really need to park the truck and get a small car for commuting to work. Otherwise you will be back at the dealers again in a year or two
Page of 5
 > "COKED UP"
