RV.Net Open Roads Forum: Tow Vehicles: Mr Truck on Econo Maxx
Search only in Tow Vehicles
 > Mr Truck on Econo Maxx
FishOnOne
The Great State of Texas
Posted: 10/31/14 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
Link
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"Built Ford Proud"
'16 Sprinter 319MKS "Wide Body"
buddyIam
Erie Trip from Hobohemia - Big Rock Candy Mountain
Posted: 10/31/14 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
How long have these been around. The OEM's are scratching their heads trying to get more power and more mpg but none have adopted this.
With turbos and direct injection the 'swirling the air argument' sure doesnt seem obvious. I used to think carb or port injected engines could possibly benifit but these claims about the effect on these diesels. Sure have me scratching my head.
Doesn't the turbo swirl the air enough. At least one installation shows them putting it in between the air filter and the turbo.
* This post was edited 10/31/14 09:21pm by buddyIam *
RCMAN46
NorthWest
Posted: 10/31/14 11:38pm Link  |  Quote  |  Print  |  Notify Moderator
Mr Truck did say that there was no change in loaded mpg or 0-60 on the Duramax.
What does this tell us about the induction system that the Duramx uses VS the Ford?
buddyIam
Posted: 11/01/14 03:23am Link  |  Quote  |  Print  |  Notify Moderator
Ford is using the centrally located turbos on their diesel engines. Just thinking about it, it would seem to be great design for a forced intake direct injection engine.
Super short exhaust feed into the turbo would mean less loss of heat.
darsben
Central and Northern NY/ Casa Grande, AZ
Posted: 11/01/14 07:40am Link  |  Quote  |  Print  |  Notify Moderator
"BUT WAIT IF YOU ORDER NOW" type of product.
Traveling with my best friend my wife!
Dakota98
Idaho
Posted: 11/01/14 08:15am Link  |  Quote  |  Print  |  Notify Moderator
[emoticon]
Are there any current Forum members using this, out there ?
Please let us know.
* This post was edited 11/01/14 02:21pm by Dakota98 *
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
BenK
SF BayArea
Posted: 11/01/14 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Guess it was inevitable for these things to come back... [emoticon]
They did have a basis in application with manifold fueled.
The Vortex and Bernoulli affect does have some real benefits with
manifold fueled. The droplets do bet vaporized 'better' or 'more'
in the manifold with those two affects...as does just lengthening the
manifold runners
But with direct injection, there is no fuel in the manifold to vaporize
Just noodle this: the cross section of these things SUBTRACTS from
the cross section area of the manifold run. Plus the 'swirl' (Vortex)
interrupts air flow...something you do NOT want to do on an intake
manifold...anyone know what flow matching and polishing intake manifolds
do for the performance of any ICE?
Yes, the Bernoulli affect does change the pressure, but that is
mainly a good thing for venturi fueled systems (carbs...NOT TBI, nor
port, nor direct)
Wished I thought of selling these again on direct injection gassers
Those brothers will become millionaires very soon...if not already
-Ben Picture of my rig
ib516
Way up north eh
Posted: 11/01/14 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon]
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
All above are sold
Current: 07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
catfishmontana
montana
Posted: 11/01/14 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
Some current/recent model cars and trucks actually have devices in place to straighten the air flow/ remove turbulence.
2016 F350 Platinum Dually, CC
2014 Cyclone 3800 toyhauler
B&W Companion 20K
Turtle n Peeps
California
Posted: 11/01/14 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Only the addle minded and slow people would believe that this thing would work.
1:55, "we put it on a shop vac to see what kind of restriction we would get and the wind went from 14 mph to 18 mph."
Now lets think about this for a few minutes. Wind speed and wind VOLUME are two entirely different things. I could bolt a small runner intake on my engine and the intake air runner speed would go through the roof. I would have very little wind volume and that is what make power.
In fact if I dropped the 3" pipe coming out of the leaf blower down to a 1 inch pipe and measured the wind speed the wind speed would probably be over 30 mph. Big deal, I'm still losing a ton of volume.
4:25 to 4:30 "I tested it on my F250 and I was getting 2 1/2 miles to a gallon with a gas engine in it."
Really? And just how does that work. Most of us know that a gas engine has to run at stoichiometric volumes. 14.7 part air to 1 gasoline. So how does this gadget give you better fuel economy when the O2 sensor sees more air it gives the engine more fuel?
5:45 to 6:00 "you product will burn 30% more of the burn in the cylinders, aaaaa, you're burning more of the oxygen and more of the fuel that comes in."
What a moron. Even my old 340 engine with no cats burned everything except 14 parts / million of gasoline. My BMW burned everything. 0 parts / million on the last smog test. There was not HC's coming out my exhaust. And this idiot says he picked up 30%!! ROTFLMAO.
6:30 to 6:45 basically the product came from racing."
You bet. I bet Erica Enders has 3 of them on her pro stock car. So that's why she is doing so well!!
PT was correct!! [emoticon]
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
