RV.Net Open Roads Forum: Beginning RVing: tv
njtony
indiana
Posted: 12/25/16 09:04am Link  |  Quote  |  Print  |  Notify Moderator
On both my t.v.s on one channel only I have snow.I am on a cable system and have checked other campers tv. They have a clear channel. All my other channels are perfect. Have turned off heaters. Any suggestions?
wildtoad
Blythewood, SC
Posted: 12/25/16 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Turn off tv antenna booster and then rescan for channels. The booster interferes with cable. I assume you have set the tv to cable and not antenna.
Tom Wilds
Blythewood, SC
MarkTwain
Northern, Ca. , USA
Posted: 12/25/16 10:22am Link  |  Quote  |  Print  |  Notify Moderator
X2, TV booster blocks reception when you are hooked up to cable.
Wherever I happen to park
Posted: 12/25/16 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
If it is only one channel and only that channel, is it possible the other campers are not watching that channel?
Sometimes on cable TV there are channels your TV will scan, but can not "Decode" or to be more precise de-encrypt. These are premimum channels and you need to pay to play that programming.
Home is where I park it.
Lynnmor
Red Lion
Posted: 12/26/16 08:27am Link  |  Quote  |  Print  |  Notify Moderator
To be more precise, the little switch not only turns the power on to the amplifier it switches between the cable and antenna inputs. In other words, the cable input is disconnected in the on position.
njtony
indiana
Posted: 12/26/16 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
On a cable system. Other campers tv are ok. Have tried rebooking tv same thing. Un pluged anything pu
Plugged in.no luck. It's a local channel. Its weird that only one channel is effected. Guess I just live with it. Thanks to all.
wbwood
Lake Norman, NC area
Posted: 12/27/16 05:55am Link  |  Quote  |  Print  |  Notify Moderator
It could be something to do with that site. Have enough cable to run to another sites cable connection? If so, ask a neighbor to see if you can try it for a couple minutes. At least that way, you will know if it's your site or your rig.
Brian
2013 Thor Chateau 31L
Effy
NC
Posted: 12/27/16 05:58am Link  |  Quote  |  Print  |  Notify Moderator
Have you tried what several people have told you to do - turn off the antenna booster?
2013 ACE 29.2
dwayneb236
Benbrook Texas
Posted: 12/28/16 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure I understand about the booster being checked. Wouldn't none of the channels be working if the booster was on. He's saying all channels work great other than one. Seems like that's not a booster issue since no other channels are affected.
2016 Ford F350 XLT DRW 6.7 SuperCrew 4X4 8 Ft Box
2016 Brookstone 395RL
wbwood
Posted: 12/30/16 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
That's what I am understanding as well...
