RV.Net Open Roads Forum: Beginning RVing: How bad are converters on batteries?
 > How bad are converters on batteries?
prichardson
Lafayette, La
Posted: 12/31/16 08:24am Link  |  Quote  |  Print  |  Notify Moderator
I would charge fully, ensure proper water level, make sure the top is clean and dry and disconnect the battery. With any charging system, the water level needs to be monitored.
cyntdon2010
Jacksonville, Florida
Posted: 12/31/16 08:25am Link  |  Quote  |  Print  |  Notify Moderator
check battery water every month..
2010 lacrosse T.T 318 bhs 34 ft,blue ox-tow bar,2005 FORD F-150 larait super crew,Firestone ready rite-air bags lift kit
BarneyS
S.E. Lower Michigan
Posted: 12/31/16 08:53am Link  |  Quote  |  Print  |  Notify Moderator
sonora wrote:
Ava wrote:
It is the older converters that do not have a three stage charging cycle that are hard on batteries. The continuous charge on older units can boil the battery dry if not checked on regularly as far as I understand.
Would a mid 90's converter be an "older" one?
Yes,chances are good it is an older one.
If you would post the make and model of your converter someone will be able to tell you whether it is a "modern" one with the 3 or 4 stage charging circuit.
Barney
Hensley "Arrow" 1400# hitch
2019 Ram Limited 1500, 5.7L Hemi, 4x4, SB
Wherever I happen to park
Posted: 12/31/16 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Well.. you stated a modern 3-stage converter.
A good 3-stage will baby your batteries and not damage them at all.
HOWEVFER, that said yes, there are failure modes.. The most COMMON failure mode for the converter most likely to fail is "Wont' go into Bulk (or Boost) mode,, This will not damage your batteries.. Just takes forever to re-dcharge when you are using the RV.
There are other failure modes however
NO CHARGE, period, total failure of converter.. This Short term, won't hurt anything but the batteries over time will run down
And the other failure mode which is very rare is over voltage (Leaky pass transistor for examnple) this will boil the batteries dry over time, and if allowed to continue can, in theory, cause a minor explosion and a major fire.
But,,,, in 12 years of cursing the forums.. I have NEVER heard of that from a modern 3 stage converter. Only from one that was discontinued last century and then no fires.. Just dry batteries.
Home is where I park it.
Matt_Colie
Southeast Michigan
Posted: 12/31/16 11:28am Link  |  Quote  |  Print  |  Notify Moderator
Sorry,
But without the make and model number, nobody can tell you. There were some good converters at that time, but they were few.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
ksg5000
Oregon
Posted: 12/31/16 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Maybe/probably? If you know the model number - post. If you don't have ready access then measure the electric output ... older converters often put out a constant 13.6 volts which tended to deplete the battery water and those who didn't maintain water ended up with dead batteries.
Kevin
rskrbina
NW Missouri
Posted: 12/31/16 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
afidel wrote:
time2roll wrote:
If that modern converter is a WFCO all bets are off. Measure the voltage after a week and see if you actually see storage mode at 13.2 volts.
Regardless you still need to check the water level periodically.
See, that was my worry. It's a two hour round trip (during good weather) to my storage so the chances of me going during the next few months are pretty much nill. I think I'll pick up a timer and just set it to go for an hour or two a day which should be plenty to keep up with the small parasitic loss from the CO/LP detector and the stereo (or should I pull the stereo fuse?).
Hello Andy. Use your battery disconnect switch and you won't have to worry about parasitic loads while storing your rv.
Sorry, I read your post a little closer, please disregard.
* This post was edited 12/31/16 12:54pm by rskrbina *
Rudy, Jenny and Garrett
2014 Thor.. Four Winds 35SK Super C..F-550..6.7 Diesel
CRV, F-150 & Wrangler Sahara Toads..TST Tire monitor
afidel
Cleveland
theoldwizard1 wrote:
If you are concerned about overcharging, buy a cheap mechanical lamp timer and install it between the power source and the charger. Set it to run for a couple hours per day.
Next time you are shopping for a house battery make sure to get a TRUE deep discharge battery. Most "marine" batteries are dual purpose and therefore are a compromise between starting and powering things.
Yup, plan to upgrade to 2x golf cart batteries, the marine unit was what the dealer included in their prep package and I'm not even sure how much dry camping we'll be doing.
2017 KZ Sportsmen Classic 181BH
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
E2 WDH
afidel
Cleveland
Posted: 12/31/16 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
None in my trailer and I was going to add one but the most logical place would be at the tongue box but then the converter can't keep it topped up and 5 months of loss would be bad for battery health. I think I'll just try with the converter on a timer this season and see how it goes.
dodge guy
Bartlett IL
Posted: 12/31/16 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Why not just get a maintainer and hook that up to the battery. They are only $20-50 and are automatic.
Wife Kim
Son Brandon 16yrs
Daughter Marissa 15yrs
Dog Bailey
07 Cherokee 32B Dexter EZ Flex
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese DualCam Prodigy brake controller
A bad day of camping is
