RV.Net Open Roads Forum: Beginning RVing: GVWR
Viajera1
NM
Posted: 12/31/16 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
GVWR What is it.. I know it is about wt, but that's all.
Boxer Lovers
Fort Smith, AR
Posted: 12/31/16 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
Gross vehicle weight rating.
Dave, Robin, and Buster the Boxer
2008 Beaver Contessa, 42, Caterpillar 425
Toad 2017 Ram 1500, Quad Cab, Limited, M&G brake, Blue Ox.
artman
Boise Idaho
Posted: 12/31/16 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
Assuming you are pulling a trailer you will have gvwr for TV and TT.
You will have GCVWR which is Combined weight.
2017 Arctic fox 27-5l
wildtoad
Blythewood, SC
Posted: 12/31/16 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Basically it is the maximum weight your vehicle can weigh including itself, all passengers, cargo, gas, water, food, clothes, tongue weight, and anything else supported by the tires and axles.
Tom Wilds
Blythewood, SC
1492
Washington, DC
Posted: 12/31/16 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support
DrewE
Vermont
Posted: 12/31/16 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Here's a rundown of the weight ratings:
GAWR -- gross axle weight rating, the maximum weight that the axle and its suspension is designed to support. There would be a separate GAWR for each axle.
GVWR -- gross vehicle weight rating, the maximum weight on all the axles of the vehicle added together. This may be (and usually is) less than the sum of the GAWRs.
GCWR -- gross combined weight rating, the maximum total weight of the vehicle and and any towed trailers or cars or whatever.
If you have a trailer, the tongue weight would get included along with the weight of the vehicle and occupants and cargo against the GVWR. The total trailer weight is included against the GCWR.
A trailer hitch also has a weight rating (the maximum weight of a trailer that may be connected to it) and a tongue weight rating.
Old-Biscuit
Verde Valley
Posted: 12/31/16 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
FAQ Link at top of Beginning RVing----Terminology
BarneyS
S.E. Lower Michigan
Posted: 01/01/17 10:17am Link  |  Quote  |  Print  |  Notify Moderator
The key word in all of these is rating,
This is not what the vehicle actually weighs, but the maximum that it can weigh.
Barney
Hensley "Arrow" 1400# hitch
2016 Ram Laramie 2500, 6.7L CTD, 4x4, SB
Terryallan
Foothills NC
Posted: 01/01/17 10:41am Link  |  Quote  |  Print  |  Notify Moderator
All true answers. It is what the manufacturer warrants the vehicle to weigh. Going over the GVWR is NOT illegal, but "can" void the warranty.
Having said that. I do not advocate carrying more than the manufacturer rating. they spent lot of time, and money figuring the weights the vehicle can carry with out damaging it. But a 100lb here or there will not cause the vehicle to explode.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Posted: 01/01/17 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
Barney
Popcorn time!
The definitions are correct, however, it is not the max amount a vehicle "can" weigh. It is the rated max weight for a given class of vehicle. Some vehicles are much closer to being actually overloaded, when at their gvwr, than others.
3/4 ton trucks are the classic example of this. They have relatively low gvwr for their apparent capabilities, being basically the same as their 1ton single wheel counterparts, they typically have minor rear suspension differences, but the gvwr is limited to that of a class 2 truck, mostly for regulatory purposes. Essentially 2 identical trucks save for factory rear suspension capability can be configured that have almost 2500lbs difference in gvwr. Some older models were actually the same truck literally with a lighter classification assigned by the mfg.
To keep the weight cops here in check, I'll add that caution should be taken in exceeding gvwr. One should know what they are dealing with before doing so.
03 Arctic Fox 860
07 Dodge 2500 deezul
