RV.Net Open Roads Forum: Is installing a hitch receiver a reasonable DIY job?
Search only in Towing
Open Roads Forum  >  Towing
 > Is installing a hitch receiver a reasonable DIY job?
kokotg
Metro Atlanta, GA
Posted: 01/05/17 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
We just bought a new toy hauler, and we're pushing up against the limits on tongue weight for our current hitch receiver, so we're planning to upgrade it. I found one that says no drilling required; bolts should match up with the holes that are already there...any reason we can't install it ourselves? My husband is reasonably handy in a general sort of way but without much experience working on cars specifically...but my brother, who does have a lot of experience with that, will be here to help. Husband's nervous about it, since the consequence of messing it up would be losing the trailer on the highway somewhere....but it sounds like a pretty straightforward job to me. Thoughts?
Camping with 4 boys and 3 dogs in a Jayco Octane Superlite 272
Blogging at Boxy Colonial on the Road
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 01/05/17 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
I'd do it myself. The worst that happens is that the holes don't line up. Then it's a decision as what to do at that point - either fix the holes or get a different hitch.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
MFL
Midwest
You should have no problem swapping the receivers. It is pretty straight forward, just follow torque instructions to keep it secure. Best be sure tow vehicle is up to the capability, to match the new receiver. There may have been a reason it had a light duty set up.
Happy wrenching,
Jerry
kokotg
Metro Atlanta, GA
Posted: 01/05/17 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
Happy wrenching,
Jerry
Trailer has a heavy hitch since it's a toy hauler....It's 7000 pounds dry, and our van's tow capacity is 10,000 pounds (which is right at the max weight of the new trailer, but we'll never come close to that; the main "toys" we're going to haul are bikes and maybe kayaks--we figure we'll top out at maybe 8500 or for a long trip). Current hitch receiver is only rated for 1000 pounds, and Jayco lists the dry hitch weight at 985.
spoon059
Just north of D.C.
I've done it a couple times. Make sure you have the right hitch for your vehicle, make sure you are using the right torque specs and its pretty easy to DIY.
2015 Ram CTD
2015 Jayco 29QBS
MandKJohns
Posted: 01/05/17 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
It's as straight forward as it gets. Unbolt the old receiver, drop it down out of the way. Bolt the new one back in its place. Bolt pattern should match just fine just make sure the hitch you buy is for your vehicle.
Durb
Clark County, Washington
Posted: 01/05/17 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
I've installed a couple of receivers and they are not difficult. I found the hardest part was lifting it into position to get the bolts started as they are a little heavy. An auto jack on rollers really helped.
2004.5 Ram 3500, CTD, 2WD, DRW, PacBrake, Banks intake and Monster Exhaust
2008 Carriage Domani DF300 fifth wheel
TrailerSaver TS3
IdaD
Idaho
Posted: 01/05/17 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, just have a good heavy torque wrench so you can torque the bolts to spec. I've installed hitches and fifth wheel rails myself and the former is easier.
2015 HD Ram Cummins 4wd CC/SB
kokotg
Metro Atlanta, GA
Posted: 01/05/17 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
thanks everyone! I'll check and make sure my brother has the right tools to bring along; sounds like they should be able to handle it no problem.
rexlion
Broken Arrow OK
Posted: 01/06/17 10:16am Link  |  Quote  |  Print  |  Notify Moderator
I'm not very handy but I have installed my own hitches a couple of times. It was not difficult at all. The last one I even did by myself, using a jack stand to hold up one side while I started a bolt on the other side. A torque wrench is advisable.
Mike G.
--currently in between trailers--
To every thing there is a season, and a time to every purpose under the heaven... (Ecclesiastes 3)
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
