RV.Net Open Roads Forum: Folding Trailers: Towing speed for small pop up ?
 > Towing speed for small pop up ?
NanciL
Bakersville, NC,/Key Largo FL
Posted: 01/06/17 03:10am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone tow a small pop up trailer at 70 or 75 MPH ?
jack L
Jack & Nanci
flat_twin
Ohio
Posted: 01/08/17 11:53pm Link  |  Quote  |  Print  |  Notify Moderator
I don't tow anything much above 65 mph. Any trailer tires I've seen have 65 mph max stamped into the sidewalls. I have towed a small vintage tent trailer with 8" wheels at 65 mph with no problems. The tires are new and the bearings were serviced recently. I felt the hubs at every stop and they were only warm.
A big bump in the road, a pothole, or any kind of unanticipated reason to swerve or brake hard would be a lot easier to handle at lower speeds.
MiPaJacks
Dallas
Posted: 01/09/17 08:14am Link  |  Quote  |  Print  |  Notify Moderator
Hi Nanci,
Check your tires, if your pop-up has small tires towing at 70 mph is too fast. Better to plan on staying in the 60 mph range.
NanciL
Posted: 01/09/17 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks,
We are used to pulling a 25 footer and are thinking of getting the smallest pop up available and were wondering if we could go the same high speeds.
Jack L
Biker1mike
Gallatin, NY
Posted: 01/11/17 05:43am Link  |  Quote  |  Print  |  Notify Moderator
My pop-up has 13 inch trailer tires rated at 65 mph. My cruise control is set at 70 on any highway with a 65 mph limit.
As an fyi, I am way below my tow weight limit.
Mike
'12 Honda Ridgeline pulling '07 Rockwood pop-up
manualman
Chicago Burbs
Posted: 01/11/17 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
I'm the same as bikermike.
I'd probably NOT do this with the old style dinky 8" wheels!
Old-Biscuit
Verde Valley
Posted: 01/11/17 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
tires have 65 mph rating
hwy has a 65 mph speed limit
cruise control set at 70 mph
That makes perfect sense---------[emoticon]
OP
I just don't get the 'need for speed when towing'
Beer Belly
Bethel, Connecticut
Posted: 01/13/17 05:30am Link  |  Quote  |  Print  |  Notify Moderator
We usually cruise along at 70 mph, but there are times I've had to go faster than I should for brief moments due to someone trying to drag race me as I try to pass, then slows back down when I pull back in behind them......I'll deal with this a couple of times before I just go for it and do what it takes to complete the pass.....I won't post the speeds, don't need to get beat up here, but do return to my cruise speed after the pass and watch the person fade back.
*Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming - "WOW, What a ride!"
Mike Up
NW Indiana
Posted: 01/13/17 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
I would not tow any trailer faster than 60 mph. Most RV tires are only to 65 mph. Why push them at their limit especially with age on them.
My cousin would tow their pop up about 70 - 75 mph and couldn't understand why he kept blowing tires. I knew of at least 3 tires he blew.
2016 Ford F150 XLT, CC, 4WD, 145" WB, 5.0L, 6 speed, 3.73 9.75" Locking Axle, 1890# Payload, SAE J2807 method Actual 10,720# Tow Rating, Pulling a 2012 29'1" Jayco Jay Flight 26BH, 8' wide, 6'9" ceiling, loaded at ~6500 lbs using a Blue Ox Sway Pro Hitch
IdaD
Idaho
Posted: 01/14/17 07:42am Link  |  Quote  |  Print  |  Notify Moderator
When towing with our Pilot I kept it at 65 or less. The summer I had the truck and pop up I would go into the low 70s. Would have gone faster but the tires were only rated for 75. I also tow my fiver into the low 70s when conditions allow. No issues.
2015 Cummins Ram 4wd CC/SB
