RV.Net Open Roads Forum: Should 2 Wheel Drive Low Range be a option??
Search only in Tow Vehicles
 > Should 2 Wheel Drive Low Range be a option??
Page of 5
Movin Easy
Ottawa
Posted: 01/08/17 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
While visiting a local hilly campground I had finished my visit and was heading to the clean out. The location of the cleanout was up a steep incline and around a bend on pavement. I had to decide to pull in 2HI and strain my transmission or choose 4LOW and risk damaging my front axle. Who else thinks trucks should offer 2 wheel drive low range as a option??
* This post was edited 01/08/17 10:41pm by Movin Easy *
austingta
Austin TX
Posted: 01/08/17 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
That wouldn't really solve the problem because 2WD with a locked rear axle would scrub too. Less, for sure, but it still would.
Frank Brooks Austin TX
2018 F 150 King Ranch max tow package with 3.55 gears
Published towing weight limit 13200
Payload per sticker 1464
ScottG
Bothell Wa.
Posted: 01/08/17 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
I'd sure ike to have it but manufacturers just dont get how convenient this wold be for those of us that have to back up trailers.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
ksss
Eastern Idaho
Posted: 01/08/17 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
I remember years ago that was an option. I had an 84 3500 SRW with a 6.2L in it. There were times when I needed the lower gear ration, not necessarily 4 X4 low. I could just not lock in the front hubs and have access to the lower gear ratio without being in 4X4. However now days with all the power these newer pickups have I don't think it is necessary.
2006 GMC 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2015 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
TUCQUALA
Kennewick, WA
Posted: 01/08/17 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing said aboot a locked rear end!!! Shouldn't enter into the equation!
OP, welcome to forum!!! What are driving?? Don't see anything in your profile. If a Ford, and have the auto vacuum hubs, there is a modification that can be done to engage 4W lo without the hubs activating. There may be something like that for other mfgs system, I don't know.
'16 Outdoors Timber Ridge 280RKS
DrawTite/Reese 1200# Round Bar w/ DualCam HP
'03 EXCURSION XLT V10 4.30 Axles
rhagfo
Portland, OR
Posted: 01/08/17 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
I added a 2 Low kit to my 2001 Ram, works very well.
* This post was edited 01/09/17 07:31am by rhagfo *
Russ & Paula
The Beagles Precious, and Belle.
2001 Dodge 2500 4X4, 5.9 Cummins, NV4500, 3.55's, Pacbrake PRXB, DS Power Puck,Bilstein 5100's, 307,000 miles.
2005 Copper Canyon 293 FWSLS, 32' GVWR 12,360# GCVW 19,500#
AJBert
xxxxxxxx
Posted: 01/08/17 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
If you really feel the need for 2wd low you could always have a divorced transfer case installed. Plan on spending a few $$$ though.
Movin Easy
Ottawa
Posted: 01/08/17 11:07pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry I drive a 2005 Sierra 2500HD. Pulls great but still has its limitations. I just really hate the feel of turning in 4WD. I swear something will snap if you turn to hard. Reading different articles about low range where they say to use it for off road and towing heavy loads. But if you can't steer what good is it. Going to find out more about this. I have a small tractor that offers hi and low range in 2 and 4 wheel drive. For a little tractor you can move lots in 2low without the binding.
MFL
Midwest
Posted: 01/09/17 06:30am Link  |  Quote  |  Print  |  Notify Moderator
I have a Ford with the auto vac hubs, and would like to hear more about this mod. Could you post a link, or give a brief description of this mod? I understand that pulling off vac line would work, but an easy mod kit would be great.
Jerry
mowermech
Billings, MT
Posted: 01/09/17 06:43am Link  |  Quote  |  Print  |  Notify Moderator
There have been many vehicles that could be put in 2LO. AFAIK, it has always been recommended against by the manufacturers, because of the excessive torque that could be applied to the rear driveshaft and axle shafts.
The driveshaft and/or axles shafts could be twisted it two.
Yes, it can happen. I have seen the results in trucks and electric forklifts (lesson learned: NEVER use reverse to stop when the brakes fail. That 2 inch axle shaft WILL twist in two!)
CM1, USN (RET)
Daily Driver: '06 PT Cruiser Turbo
Toy: 1999 Dodge QC LWB, Cummins, Automatic, 4X4
Other toys: a pair of Kawasaki Brute Force 750 ATVs.
Page of 5
