RV.Net Open Roads Forum: Travel Trailers: Mice Proofing
 > Mice Proofing
Chaz59
Stephenville, TX
Posted: 01/10/17 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
What is the best option to keep mice out of TT. Do the peppermint sprays really work. I don't want to use moth balls or anything toxic.
I do have the bottom sealed pretty good but a mouse can always find a hole.
thanks
Charles
donn0128
Pronounced Ore-gun
Posted: 01/10/17 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
Best is to prevent entry in the first place. Big box stores sell rodent proof spray foam. Add steel mesh, steel wood it something like that that they cannot chew through followed by the foam spray and they will not be able to get in.
Don,Lorri,and Charlie Bear 2016
The Other Dallas
rbpru
North Central Indiana
Posted: 01/10/17 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
Everybody has their own techniques. There is no universal method that works for all parties all the time.
You can try various elixirs but I have found that sealing as good as you can and traps work as well as anything. This assumes you can check the traps before the mouse starts to smell.
Personally, I am convinced mice can, at times, walk though walls. [emoticon]
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
NYCgrrl
Posted: 01/10/17 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
X2
and you can add glass shards to the steel wool if you like.
As a managing agent I once witnessed the damage a rat did to a porcelain tile embedded in several inches of cement floor. Overnight he made it through at least 3 inches of the floor before the exterminator arrived[emoticon]
midnightsadie
ohio
Posted: 01/10/17 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
not peppermint spray,,peppermint oil. and fresh cab works for me. farmers use the product fresh cab in there big machines.
ScottG
Bothell Wa.
Posted: 01/10/17 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
I think one of the best things you can do is get rid of everything and anything they would consider food. This means not only real food but medicines, chemicals, etc.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
TNRIVERSIDE
East Tennessee
Posted: 01/10/17 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
As stated. Close all entry points. If you do see signs that mice or rats are getting in try to find the entry point quickly. I have used sticky pads to catch them. Much higher catch rate that traps. I have had my truck damaged from rodents two different times now. Finally found the entry point. Good luck.
And mothballs do nothing but stink.
2014 Coleman CTS192RD. 2009 F150 4X4, 5.4, 3.31
Jeff
mike-s
Michigan
Posted: 01/10/17 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
Seal as best you're able. In my experience, nothing which won't keep you out will keep them out (except a cat [emoticon] ). Glue and multi-catch traps are good, because they capture them quickly, hopefully before they cause damage. Supplement with bait traps. I've never had a problem with dead mice stinking things up - they're small and dry out pretty quickly after they die. The smell comes more when they're around long enough to build nests and pee on things - hence the traps.
TNRIVERSIDE
East Tennessee
Posted: 01/10/17 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
One concern I would have on bait traps. Some might have an attractive ingredient that might actually attract mice. I have stoped using any bait traps inside my TV and TT.
FULLTIMEWANABE
De Winton, Alberta
Posted: 01/10/17 10:44pm Link  |  Quote  |  Print  |  Notify Moderator
We've used Bounce Sheets scattered all over the RV for years, when placing into winterising storage on an acreage and never a problem, except the one year we forgot and there was evidence everywhere.
It Takes No More Effort To Aim High Than To Aim Low - Reach For The Stars
 > Mice Proofing
