RV.Net Open Roads Forum: Tow Vehicles: TFLTruck tests 2017 Chevy 3500
Search only in Tow Vehicles
 > TFLTruck tests 2017 Chevy 3500
Travlingman
Jonesborough, TN
Posted: 02/11/17 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
The first test of the 2017 Chevy 3500 DRW. Looks like the Ike Gauntlet should happen in the next few days. 2017 Chevy 3500
2017 F-350 King Ranch DRW
2014 Landmark Savannah
Cummins12V98
on the road
Posted: 02/11/17 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
They SAY the Allison is so robust nothing needed to be done. I don't believe that! I think that is exactly why they have a very low tow rating. Maybe next year they will have the trans strong enough to handle 31-32k like Ford and RAM already do.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 02/11/17 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
The 2016 Duramax was pushing the limits of the Alison 1000 in it's present form then. They have stayed out of the power race for a reason and it was not the Duramax or the AAM rear axle. Chris
2015 RAM 3500 CC SB SRW Our Rig New 2017 Bighorn 3575el. Retired and enjoying it!
4x4ord
Canada
Posted: 02/12/17 03:38am Link  |  Quote  |  Print  |  Notify Moderator
Too bad they can't put a 30,000 lb trailer behind the GMC.
* This post was edited 02/12/17 04:22am by 4x4ord *
2017 F350 SRW Platinum short box 4x4.
B&W Companion
Cummins12V98
on the road
Posted: 02/12/17 07:39am Link  |  Quote  |  Print  |  Notify Moderator
How are they going to compare the big three? Are they going to dumb down the other two to tow 23k???
4x4ord
Canada
Posted: 02/12/17 09:00am Link  |  Quote  |  Print  |  Notify Moderator
I get the idea they are going to test all three trucks again. Both the Ford and GM should have just enough power to tow 23000 lbs up the hill at the 60 mph speed limit. With 3.73 gears the Ford would be running about 2600 rpm in 4th gear at 60 mph. The Chevy would only be turning about 2275 so maybe the Ford will have the advantage. If it ends up that both trucks drop to third gear the advantage will be in GM's favor.....
If the Ford can't manage 60 mph it might have to drop to third and rev to 3000 rpm where it's only able to do about 52 mph. If the Chevy drops to 3rd and revs to 3000 rpm it will be making 57 mph.
I'm going to guess 8 minutes 40 seconds for the winner.
IdaD
Idaho
Posted: 02/12/17 09:18am Link  |  Quote  |  Print  |  Notify Moderator
The timing on those tests would have merit if there wasn't traffic, or if they went full throttle all the way. But there is traffic, and they don't go full throttle. Given that, the times don't mean much of anything. With an equal load I would expect the Duramax to be the fastest followed by the Powerstroke and then the Cummins. In the real world they're all plenty fast and powerful, though - it literally wasn't something I even considered when I evaluated the three.
2015 Cummins Ram 4wd CC/SB
blofgren
Surrey, B.C.
Posted: 02/12/17 09:37am Link  |  Quote  |  Print  |  Notify Moderator
x2. Even with higher ratings the Ford just can't seem to outpull the GM. It's surprised me a couple of times.
My lowly G56 powered Cummins would be a couples of minutes behind everyone but it will keep doing it reliably for years to come with less heat and easy maintenance so I'm OK with that!
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
FishOnOne
The Great State of Texas
Posted: 02/12/17 11:56am Link  |  Quote  |  Print  |  Notify Moderator
The GM and the Ford will perform this task reliably for years to come too, and the maintenance is much easier on those as well. [emoticon]
Looks at it this way the truck that can pull up a hill the fastest is typically the truck that can pull that load the easiest.
Towing Just Got Easier! [emoticon]
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"Built Ford Tough"
'16 Sprinter 319MKS "Wide Body"
Travlingman
Jonesborough, TN
Posted: 02/12/17 11:57am Link  |  Quote  |  Print  |  Notify Moderator
2017 Ford F-350 diesel dually doesn't come with a 3.73 gear.
