RV.Net Open Roads Forum: Class A Motorhomes: Gasser Extended Trip and Oil Changes
 > Gasser Extended Trip and Oil Changes
ratfink09
NYS
Posted: 02/15/17 06:26am Link  |  Quote  |  Print  |  Notify Moderator
We have an extended trip out west this summer planned which will include about 7500 miles of driving. We have a 2017 Tiffin 35 QBA Ford gasser chassis. The Ford manual says you can go 7500 miles between oil changes without towing. I am planning an oil change to Motorcraft synthetic oil before we go. I would like to avoid having to get service during our trip. Sound good to you all?
TNGW1500SE
Oliver Springs TN
Posted: 02/15/17 06:31am Link  |  Quote  |  Print  |  Notify Moderator
You're set. Just check it from time to time and bring an extra quart
crasster
Dallas
Posted: 02/15/17 06:44am Link  |  Quote  |  Print  |  Notify Moderator
Sure sounds good to go. Just be sure to check the level now and then.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
Bumpyroad
Virginia
Posted: 02/15/17 09:33am Link  |  Quote  |  Print  |  Notify Moderator
I assume you are not towing?
I would change it at 7,499 mi my self.
bumpy
Effy
NC
Posted: 02/15/17 09:41am Link  |  Quote  |  Print  |  Notify Moderator
No need to change during your trip. Do it before you leave and when you get back. I assume Bumpy was making a point that who really gets their oil change to the exact mile. Sometimes I do mine at 7k, sometimes at 8k. No harm in either case.
2013 ACE 29.2
time2roll
Posted: 02/15/17 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Even 10,000 is not a big deal. JMHO
Do check the oil level and top off as needed because low on oil is a big deal.
Matt_Colie
Southeast Michigan
Posted: 02/15/17 10:04am Link  |  Quote  |  Print  |  Notify Moderator
Rat,
Let me tell you this about that..
For a some of my time in the OE, I ran the engine tear-down and inspection room(s). At that time (20+ya) that manufacturer was calling for a 7500 Lube Oil Service interval. It was SOP for the proving ground to run X2. I never saw lube oil related failures that were not first material failures.
The real problem with modern engines and long service intervals is not that the lube oil gets worn out (new oils are amazing in this regard) but that short cycling fouls the oil with moisture and other combustion by-products. the biggest problem those present is corrosion.
Now, you are going to switch to a synthetic, good move. There are two benefits to synthetics. First is temperature breakdown resistance. I suspect that will not be a big issue to you. But the other is the resistance to the formation of acids that can lead to corrosion of the oil wetted components. Unfortunately, you will not get the full benefit until after the next oil change. It takes an extensive procedure to get even 90% of the lube oil out of an engine.
As you will not be short cycling the engine during this excursion, you will be in good shape.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
howdy35
Athens, Texas
Posted: 02/15/17 11:52am Link  |  Quote  |  Print  |  Notify Moderator
In 2002 we took a trip to Alaska 56 days, 14,300 miles. Changed to Amsoil synthetic before the trip and changed again when we got back. Towed a Honda Accord and went up and down and up and down the mountains. The 1999 Bounder with the V-10 performed flawlessly even though it would scream and wind pretty tight going up the slopes.
Like others have said, I wouldn't worry about the mileage, just keep it topped off. Have a great trip. Arnold
1999 National Tradewinds 7370
2014 Honda CR-V--Toad
Fulltime Wanabee
Bumpyroad
Virginia
Posted: 02/15/17 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
no I was semi-serious. it is a new vehicle with warranty. I remember somebody posting here that they had some issue with a non-oil change part and notified the dealer that they had changed the oil at what was 50 miles over the "required" distance, and they pounced on that and denied the claim under warranty.
I like to play it safe myself.
bumpy
Heisenberg
West Texas
Posted: 02/15/17 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
You say 2017.....I would advise you to do 3000 or more miles on the oil for break in. With the original oil removed you can then go the limit with synthetic. Just my 2 cents.............
2013 Winnebago Sightseer
2014 Jeep Wrangler Sport
