RV.Net Open Roads Forum: New to RV world, I have a few questions
 > New to RV world, I have a few questions
masdrobeda
Taunton
Posted: 02/16/17 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
First of all I am very new to the RV world. I am planning to live in a RV for a few years as I am moving from Boston to L.A.
I am very much between a TT and Motorhome.
I currently own a car.
My budget: ~40K loan (will finance everything)
Option 1:
Sell my car and pay off my car load (I will probably be even on it), buy a truck and a TT (both used)
I have found decent TT for around 20K and also either a newer 1/2 truck (2012, 2013) for around 20K or a 3/4 truck (2009, 2010) for about 20K also
On this option 1 I am looking to get at least 33 foot Trailer and, I was wondering if any 1/2 ton will be able to tow it or I need a 3/4 ton truck after all? I would definitely prefer a 1/2 ton truck because once I get to my destination, I will be using that same truck to drive around, go to work, etc. I think the MPG difference and price difference is quite big between 1/2 and 3/4 truck.
Option 2:
Buy a used Motor Home class A and tow my current car.
On this option 2, I would preferred a diesel engine 35-37 footer (like a bus) kind of motor home. I have found one or two 2001, 2002 for 30K.
I believe option 2 is a easier transaction because I only need to buy one thing and a relatively simple hitch to pull my car and I am good to go. However, is it a good option if I am planning to live in it and perhaps not drive the motor home at all for 1-2 years ?
Too many question to ask but that is pretty much what in my mind at the moment.
I hope I made it clear.
Thanks for the help in advance and please I want to hear what you think!
toedtoes
California
Posted: 02/16/17 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Seems to me if you're going to finance the entire thing, you're better off spending those monthly payments on rent for an apartment.
1975 American Clipper RV with Dodge 360 (photo in profile)
DownTheAvenue
Sunny South
Before you decide on option 2, make sure you can tow your car. Some vehicles can only be towed on a dolly or trailer. Also, be sure to research the expense associated with towing your vehicle. It can be expensive.
El Pueblo de Nuestra Senora Reina Los Angeles
Posted: 02/16/17 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
I am concerned that you will lock yourself into a lifestyle you have never experienced....all financed.
2015 Winnebago 2101DS TT & Chevy Tahoe LTZ, 300 watts WindyNation solar - parallel & MPPT, Trojan T-125s. TALL flagpole for USC & historical flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county campgrounds. 14 year Army vet. Bicyclist!
BizmarksMom
Idaho
Posted: 02/16/17 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
If your car is flat towable, I'd go with the motorhome.
If you decide to go with the trailer option, a 1/2 ton truck is not going to happily handle a 33' trailer. You're better off going with the 3/4 ton.
2011 F150 towing a Nash 22H
MarkTwain
Northern, Ca. , USA
Posted: 02/16/17 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
masdrobeda wrote:
Hello,
Option 1:
33' trailer will need at least a 3/4 ton diesel truck but ideally a 1 ton truck. The difference in ride comfort is minimal.
Milage is about the same.
Option 2:
Any RV over 10 yrs. could end up being a "$$$ hole" to keep it maintained. Do not buy a 10 yr. old RV without taking it to your mechanic to check everything out. $200 well spent so you know how much you have to spend to get it on the road i.e. Tires along can be as much as $300 or more.
Leaving a Motor Home sitting for 1 to 2 yrs. not the best way to keep up good maintenance.
beemerphile1
Ohio
Posted: 02/16/17 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
A car or truck loan is not an issue but you may find financing a used TT or MH to be difficult. Also, after taking out one loan the odds of getting the second loan goes down.
I have always looked at it like this, a MH is great for moving frequently while a TT is best if going to be parked in one spot for a while. Of course, opinions vary.
2006 Weekend Warrior FK1900
lanerd
Home in Ridgecrest CA for the winter.
Posted: 02/16/17 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
"IF" your car is 4-down towable, be aware that you will need several items to purchase and install to accomplish that. Without going into details, if you do the install yourself, the cost will run around $2000....if you have someone do it, the cost will run around $3000.
If it is not 4-down towable and is a front wheel drive (FWD) vehicle, you can get a 2-wheel dolly to tow it. Or you can purchase a transmission lube pump If it is rear wheel drive (RWD) and is not 4-down towable, you can get a driveshaft disconnect system. In either case, you can add another $1000 to the equation.
Good luck in whatever you decide.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
masdrobeda
Taunton
Posted: 02/17/17 07:14am Link  |  Quote  |  Print  |  Notify Moderator
You have a good point. However, first of all, I am not sure where I am going to be landing a job so If I am mobile I am in a little better shape.
Second, I have been looking and its hard to find anything under $1500 a month not including that I have to find a place to accept 3 cats.
Third, rent is just money flushing away every month. With a RV, I am actually paying "rent" on something that I ended up owning in a few years (5-10 years). Also, I dont plan to live in the RV for longer than maybe 2-3 years.
Thanks for the feedback
beemerphile1
Ohio
Posted: 02/17/17 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Where you planning on parking that RV? You're going to pay lot rent (campground fees).
