RV.Net Open Roads Forum: Towing: Air bags with a WD hitch
Search only in Towing
Open Roads Forum  >  Towing
 > Air bags with a WD hitch
modern family
tampa
Posted: 04/20/17 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Would you air up the bags before or after you connect the bars?
My initial thoughts would be before I attach the WD bars. I have not purchased the bags yet so I can not test it out, just thinking things through ahead of time.
2017.. Prime Time Avenger. 32QBI
His.. 2011 F-350, King Ranch, 6.2L. Crew Cab, 4x4, 8' bed, SRW, 11,000 GVWR
Hers..2008 Ford Expedition, King Ranch Heavy Duty Tow, 3.73 gears
Sold.. 2005 Star craft, Travel Star 18SB
Sold.. 2013 Keystone Laredo, 291
atwowheelguy
Marietta, Georgia
Posted: 04/20/17 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
9,029 UVW, 11,400 GVWR, maybe 1,300 TW.
With a properly adjusted WDH, why would a F350 need air bags?
* This post was edited 04/21/17 08:59am by atwowheelguy *
2013 F150 XLT SCrew 5.5' 3.5 EB, 3.55, 2WD, 1607# Payload, EAZ Lift WDH
Toy Hauler: 2010 Fun Finder XT-245, 5025# new, 6640-7180# loaded, 900# TW, Voyager wireless rear view camera
Toys: '66 Super Hawk, XR400R, SV650, XR650R, DL650 V-Strom, 525EXC, 500EXC
GWolfe
Kansas
Posted: 04/20/17 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
I use the air bags to level my truck after loading the ATV, I use the WDH to level after hitching up. If I'm just towing the trailer and not hauling much I leave my air bags around 10 PSI and still use the WDH for the trailer.
2016 Clipper 17RD
2011 Silverado
modern family
tampa
Posted: 04/21/17 05:29am Link  |  Quote  |  Print  |  Notify Moderator
On some travels, we bring our golf cart in the truck. Our new TT is heavier than the old and she sags a bit in the rear with the cart.
Yes, I have adjusted the bars and she will still sag in the rear.
Without the cart, There is no issue.
jamesroadking
Lake City, Fl.
Posted: 04/21/17 05:44am Link  |  Quote  |  Print  |  Notify Moderator
I have Firestone airbags with a wireless controller on my F250 and a Reese 15K Lb Weight Distribution hitch. With the truck's hitch ball under the trailer receiver I air up a little putting the hitch ball into the receiver, lock the receiver, then I raise the airbag pressure up to 60 or 70 psi and raising the rear of the truck up about 4 or 5 inches to easy with the hooking up of the weight distribution bars, after those bars are locked into their friction pad holders I lower the air pressure back down to about 20 psi to where the truck and trailer are level. I found that's a lot easier and faster than using the electric trailer jack to raise the back of the truck and the trailer for hooking up and unhooking the weight distribution bars. Traveling down the roads I use the wireless controller to fine adjust the ride height to find the "sweet spot" where the trailer tows easiest.
* This post was edited 04/21/17 05:50am by jamesroadking *
jimh425
Western WA
Posted: 04/21/17 07:07am Link  |  Quote  |  Print  |  Notify Moderator
Assuming you are going to tow with the F350, I don't think you'll need the air bags. I wouldn't want to tow the 32 ft heavy trailer with the Expedition. Even if I tried, I'd avoid the air bags.
goducks10
There
Posted: 04/21/17 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Air up before hitching.
Bob/Olallawa
Kitsap Co, WA
Posted: 04/21/17 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
Unless you plan on hauling heavy in the pickup bed with out the trailer, I would save my money and not buy the air bags.
Welcome to my home, that door you just broke down was there for your protection not mine.
burningman
Seattle, WA USA
Posted: 04/22/17 11:26am Link  |  Quote  |  Print  |  Notify Moderator
It's funny how people start telling a guy whether they think he needs airbags rather than discussing the question he asked.
The airbags and the tension setting on the hitch bars both affect each other.
The first time, you'll need to do some dialing in.
If you set the weight distributing bars first then air up the bags, the bars will loosen as the truck comes up. You'll have to play around with it until you have the right combination of air pressure and bar tightness.
After that, the easiest is to hitch up, air up, then connect the bars last. If you try to connect the bars before airing up and the truck is squatting, you'll have to pull a lot harder on them to get them on.
Once you have found the happy setting where your bars are properly tensioned when the truck sits level with a little airbag help, you should be able to always use that same bar adjustment setting and adjust the airbag pressure to maintain level depending on how much extra stuff you've got in the back of the truck.
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
This is how they should have built them!
modern family
tampa
Posted: 04/23/17 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
^^^^ Thank you.. makes sense
