RV.Net Open Roads Forum: Tow Vehicles: Shift! **** You Shift!
Search only in Tow Vehicles
 > Shift! **** You Shift!
Page of 15
swimmer_spe
Sudbury, Ontario, Canada
Posted: 05/30/17 05:56am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2013 Ford F150 5L V8 Long box extended cab 4x4. I was towing a 1999 Rockwood Ultralight 24' travel trailer. The thing doesn't even weigh 3000 lbs.
There was this magical speed where on the flats, it would constantly be shifting up and down from 5-6. One click up on the cruise control, it would stay in 5th. 1 click down and it would finally stay in 6 for more than a couple of seconds.
I had Tow/Haul on. Does anyone know why this happens or what I can do about it, besides "just driving slower"
spud1957
NB
Posted: 05/30/17 06:11am Link  |  Quote  |  Print  |  Notify Moderator
When that happens, lock out 6th. May have been a bit of a head wind.
S
Greene728
Newnan
Posted: 05/30/17 07:08am Link  |  Quote  |  Print  |  Notify Moderator
What Spud said. It was gear hunting and the CC couldn't pick which one it liked to maintain set speed. In this case lock out the highest gear. Even with a trailer light as the one your towing, pulling in 6th isn't a good idea IMO anyways. 6th gear is your 2nd OD on that truck and is very tall which means it's not gonna like pulling. Turn on the OD like you did and lock out 6th gear and let that 5.0 rip!
2011 Crossroads Cruiser 29BHX (Traded)
2017 Grand Design 303RLS
2015 Ram 3500 CC 4x4 6.7 Cummins
Me and the wife and our two daughters. Life's good!
lawnspecialties
Garner, NC
Posted: 05/30/17 07:12am Link  |  Quote  |  Print  |  Notify Moderator
I have the 6.2 in my 2013 F350 I use for my landscape business. Locking out 6th when pulling my equipment trailer has become the norm for me. As mentioned, it just keeps the shifts down to a minimum.
2017 F450 Lariat 4X4 6.7L
2016 Vengeance Touring Edition 40D12
colliehauler
Mc Pherson KS USA
Posted: 05/30/17 07:16am Link  |  Quote  |  Print  |  Notify Moderator
You need to lock out sixth, hunting is hard on the transmission it creates a lot of heat.
skiles
NC
Posted: 05/30/17 07:28am Link  |  Quote  |  Print  |  Notify Moderator
I've notice the same thing on my truck at times. How does one go about "locking out" 6th?
2009 Outback 268rl
2015 F250 Lariat 6.7 Powerstroke
ShinerBock
SATX
Posted: 05/30/17 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Look for the "+/-" button on your gear selector. Press "-" to lock out or keep your transmission fro shifting into a certain gear and press "+" to unlock that gear.
For example, when driving down the road you should all gears available. If you hit the "-" button then it should take out the highest gear you are in. Some makes might display the current gear on the first press of the button if the current gear is not visible so it will take two presses of the button to actually lock out a gear in those instances. You will notice that the gear you locked out will no longer be displayed until you unlock it again.
swimmer_spe
Posted: 05/30/17 08:51am Link  |  Quote  |  Print  |  Notify Moderator
I know how to lock 6th out. I just want to use 6th. It sounds like I shouldn't. ****!
The thing is, we are taking within 5km/hr difference. I would rather go 5km/hr slower and save fuel.
carringb
Corvallis, OR
Posted: 05/30/17 09:34am Link  |  Quote  |  Print  |  Notify Moderator
As others have mentioned, it's better if you lockout 6th whole towing.
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
ShinerBock
SATX
Posted: 05/30/17 09:47am Link  |  Quote  |  Print  |  Notify Moderator
If you want that then an 3.5L Ecoboost engine would have been a better option. Its greater low rpm torque/horsepower allows it to hold higher gears than the 5.0L which needs to downshift to be at the higher rpms where it makes power. That is just one of the drawbacks of a N/A engine versus a turbocharged one.
Page of 15
