RV.Net Open Roads Forum: Tech Issues: Furnace Problem
 > Furnace Problem
harry and thea
ontario, canada
Posted: 10/11/17 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
Suburban NT-30SP. Still trying to diagnose my intermittent furnace problem. Want to make sure my thermostat is ok. I get instant fan when I turn the thermostat up. Is this normal? This model furnace does not have a time delay relay on it. Should there be one in the thermostat?
Harry and Thea
2016 F 250 cc short box
2014 Rockwood Signature Ultra Lite 8244WS
darsben1
near Canada in NYS/ Casa Grande, AZ
Posted: 10/11/17 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
You should get instant fan. Then the furnace does all its prechecks. Instant fan gives time for the fan to purge the firebox of any gas should you have a leaky valve etc. Also the sail switch has time to close the connection to allow the gas valve to open.
Traveling with my best friend, my wife in a 1990 Southwind
harry and thea
ontario, canada
Posted: 10/11/17 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks. So problem is not thermostat.
2oldman
Palm Springs
Posted: 10/11/17 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
I get instant fan no matter where the temp setting is.
Pauljdav
Everett, Wa
Posted: 10/11/17 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
All the thermostat does is provide instant power to the furnace main board. The main board desides what to do next.
I have had to replace the main board with a fans 50 plus on every furnace I have had. I recommend it as it is much better quality than the original.
darsben1
Posted: 10/11/17 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
My first check would be the sail switch
2oldman
Palm Springs
Posted: 10/12/17 09:48am Link  |  Quote  |  Print  |  Notify Moderator
Don't understand.
Joe Way
Quincy CA
Posted: 10/12/17 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
Don't understand.
THIS
 > Furnace Problem
