RV.Net Open Roads Forum: Tow Vehicles: Vibration feels like tire weight
Search only in Tow Vehicles
 > Vibration feels like tire weight
Lar's
Traverse City, MI
Posted: 11/30/17 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
After about 2000 miles on this trip I'm running down the road at about 67 or so, and suddenly there is a vibration that feels like I threw a tire weight in the front. At first I thought it was just the highway, but after many miles of different road conditions it is still there. It happens between 67 and 70 or a little higher. I checked the wheels for shiny spots where weights might have been... nothing missing.
I checked Ram web sites and found quite a few articles from other Ram owners... of course, lots of parts replaced, no resolution.
My question: Has anyone had the same experience?
If you've had a similar experience... how did you fix the problem?
I will get it out on the highway tomorrow without the fiver and see if it does the same without my 17,000 or so lbs. of enjoyment dragging behind.
2015 Ram, dually. 4x4
Lar
2015 Dynamax Trilogy
36 RL
Ram 3500 Dually
TakingThe5th
Chicago - Western Suburbs
Posted: 11/30/17 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
When you check those tire weights-check your tires as well. Make sure your tires aren't coming apart. Check for budges or tread separation. Check the age of the tires. A family member driving a Ford F350 felt similar vibration before his front left tire blew apart and nearly wrecked the rig.
TakingThe5th - Chicago, Western Suburbs
'05 Ford F350 Crew 6.0 DRW Bulletproofed. Pullrite Super 5th 18K 2100 hitch.
'13 Keystone Cougar 333MKS, Maxxfan 7500, Progressive EMS-HW50C, Grey Water System.
campinginthewoods
Central ILL
Posted: 11/30/17 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
Have you taken said tire for a balance? It might be a weight missing or could possibly be a belt shifted. My brother had a similar issue and turned out a belt had shifted which caused the vibration. His TV 2013 gmc Yukon 4x4 just a thought
"Our family is a circle of love and strength.
With every birth and every union, the circle grows. Every joy shared adds more love.
Every crisis faced together makes the circle stronger. "
Lar's
Traverse City, MI
Posted: 11/30/17 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
Thx. I'll look closer. Appreciate all advice
Artum Snowbird
Campbell River, B.C., Canada
Posted: 11/30/17 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
I would change the tires front to back and see what happens there. You should feel the vibration differently.
If you don't, I was told to drive under power where the vibration is, then shift into neutral. If the vibration lessens it could be the drive shaft. I have had different sets of wheels and tires on mine, and am now convinced it is the driveshaft... but mine is around 45 mph.
Mike and Carole
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers
newman fulltimer
louisiana
Posted: 12/01/17 06:43am Link  |  Quote  |  Print  |  Notify Moderator
if the vibration is in the seat it is the rear tires if you feel it in the wheel it is the front tires. good chance tire is starting to seperate
JIMNLIN
Oklahoma
Posted: 12/01/17 06:59am Link  |  Quote  |  Print  |  Notify Moderator
I've had front hub bearing on GM 4x4 trucks with a highway speed (above 60 mph) vibration before they go south and the grinding noise starts.
And tread belt separation vibration...however after a couple of thousand miles odd tread wear patterns starts showing up.
DennisVR
NorCal
Posted: 12/01/17 07:42am Link  |  Quote  |  Print  |  Notify Moderator
If its a dually, check rear tire pressures. Last time I had a vibration, come to fine out I had a flat inside dual.
Lar's
Traverse City, MI
Posted: 12/01/17 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Tire pressure is good all around. Can't switch front to back as they have different wheels. Thx again. I'll keep checking.
rhagfo
Portland, OR
Posted: 12/01/17 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Wheels on a DRW are all the same outside just turned around. I would also have balance checked.
Russ & Paula
The Beagles Precious, and Belle.
2001 Dodge 2500 4X4, 5.9 Cummins, NV4500, 3.55's, Pacbrake PRXB, DS Power Puck,Bilstein 5100's, 308,000 miles.
2005 Copper Canyon 293 FWSLS, 32' GVWR 12,360# GCVW 19,500#
