RV.Net Open Roads Forum: Class A Motorhomes: Urine Smell From Half Bath Toilet
 > Urine Smell From Half Bath Toilet
novi2some
Northville, Michigan
Posted: 12/05/17 08:47am Link  |  Quote  |  Print  |  Notify Moderator
On our new to me 2014 Tiffin Phaeton 40 QBH, there is an urine smell from the half bath toilet. We washed the toilet, walls and floor with Lysol cleaner. No success. The smell is more pronounced when you pick up the seat cover. Any help to stop the urine smell would be appreciated.
Happy Campers Since 1980 and still kicking.
rgatijnet1
Posted: 12/05/17 08:50am Link  |  Quote  |  Print  |  Notify Moderator
If the toilet does not hold water for an hour or so, I would guess that you have a leaky gasket.
They do have those toilet bowl deodorant blocks that hang on the edge of your bowl until you find the source.
novi2some
Posted: 12/05/17 08:52am Link  |  Quote  |  Print  |  Notify Moderator
The toilet holds water. No leakage here that is why I am stumped.
bullydogs1
OBX, NC
Posted: 12/05/17 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Some of these toilets have a plastic water dispenser which points the water to the side of the toilet..it is a small plastic piece and perhaps this plastic water distributor needs to be replaced.
Stuart and Stella Denning
2016 Entegra Aspire 42RBQ
The 3 Bulldogs (Daisy, Sylvie and Shiloh)
2007 Saturn Vue (TOAD)
Dennis12
Ridgeley WV
Posted: 12/05/17 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Did you wash the inside of the lid where you peed on it.
Dennis Hoppert
novi2some
Posted: 12/05/17 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Washed the cover and seat.
ksg5000
Oregon
Posted: 12/05/17 09:38am Link  |  Quote  |  Print  |  Notify Moderator
Few thoughts. Make sure the black water tank vent pipe is operating correctly, dump some bleach and soap in the black water tank and drive around/dump, check/replace the air vent under the bathroom sink (many bathroom sinks are plumbed to the black water tank)- they only cost about $10.
Kevin
gutfelt
North america
Posted: 12/05/17 09:42am Link  |  Quote  |  Print  |  Notify Moderator
those vents under sinks are grey water vents
gutfelt
North america
Posted: 12/05/17 09:49am Link  |  Quote  |  Print  |  Notify Moderator
its mind over matter I guarantee ;;just replace the toilet and your mind smellers will revert back to start and all will be well
stallsmi
Northern Alabama
Posted: 12/05/17 09:50am Link  |  Quote  |  Print  |  Notify Moderator
I had one where the toilet flange (where the toilet mounts to the floor) was cracked, allowing black tank odors to seep into the bathroom. It was a small crack, but when we replaced the flange, odors stopped. You would have to unscrew the toilet mounts and remove it to check.
