RV.Net Open Roads Forum: Toy Haulers: 5th Wheel suggestions with garage
Search only in Toy Haulers
 > 5th Wheel suggestions with garage
Eyetattoo
Central California
Posted: 01/03/18 11:58am Link  |  Quote  |  Print  |  Notify Moderator
The time has come to upgrade from our current bumper pull to a larger 5th wheel.
As you can see in my signature we currently have a 26ft Attitude with no slides. On the new rig we want:
5th wheel
Walk around Queen/King bed
12ft min garage with Queen beds
At least 2 slides
Access to the bedroom, bathroom & fridge with the slides in
Hoping to stay between 30-38 feet.
Thanks for the suggestions, hoping it will save us time when we go window shopping!
2015 2500HD Duramax LTZ Crew Cab
2005 26' Attitude Toy Hauler
2007 GSXR600
2004 YFZ450
2006 TRX90
2013 Raptor 90
2007 Raptor 350
Is it time to camp yet?!
azdryheat
Tucson, AZ
Posted: 01/03/18 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
Best thing to do is to wander dealer lots or visit an RV show.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
Second Chance
Wherever...
Posted: 01/03/18 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
X2 ^^. While you're doing that, keep in mind the rear axle capacity of your 2500HD and use 23% of the fifth wheel's GVWR off the sticker for an estimated loaded pin weight - NOT the published pin weight from the manufacturer. Many fifth wheels in the range you are describing will have more pin weight that you can safely put on a 3/4-ton truck.
Rob
U.S. Army retired
2016 Grand Design Reflection 337RLS
MOR/ryde independent suspension, disc brakes, LR G tires
PullRite OE 18K, Demco Glide Ride pin box
2012 F350 CC DRW Lariat 6.7
Wherever we are for however long we stay...
dedmiston
Valencia
Posted: 01/03/18 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
5th wheel
At least 2 slides
It's going to be tricky to fit everything you want into 30-38 feet.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
PhilipB
MO
Posted: 01/03/18 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
WE just bought a used 2013 Raptor 310TS, which would fit your description. It's 36.5 ft. with 3 slides, walk around king, and 10 ft. garage.
Grand Design Momentum 328M would fit your profile, except garage size.
Anything much smaller than 38 will likely have a garage that extends into the living area. This may/may not be a problem for you.
2015 Ram 2500
2013 Raptor 310TS
busterja21
Elizabeth CO
Posted: 01/03/18 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
have you checked the puma 351thss, only 1 slide, but its a big slide (sofa and dinette) and weights are reasonable for a 3/4 ton. unfortunately its not a widebody which is a deal breaker for me.
2008 CC SB Duramax
2004 Extreme 27 TXG Toyhauler
2005 Yamaha grizzly 660 (mine)
2000 Yamaha Kodiak 400 (hers)
50 CC Dirt Bike w/ trainers (boys)
JAC1982
Brighton, CO
Posted: 01/04/18 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
Our Impact 351 fits all of your requirements except for the access... bedroom and bathroom aren't accessible with the bedroom slide closed. Comes in at 38'1". I'm not sure I've seen a hauler that would fit the access requirement.
Check out Dutchman Triton and XLR Nitros, both have models that fit the requirements except the slide part.
Also, nice to see other Central CA folks... I grew up in Visalia and went to Fresno State [emoticon]
2017 Keystone Impact 351
2017 Ford F350 DRW King Ranch
2016 Ford Explorer Sport 3.5 Eco-Boost
2015 Polaris RZR 900S
CampingN.C.
North Carolina
Posted: 01/04/18 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
Also check the new Jayco Talon lineup. I've got the 413 on order. Not sure about the frig access but the bedroom is fully accessible and it has a 13ft garage. They are a new line for 18 so there's not many out yet.
Two year warranty and structurally built the same as the Seismics only a watered down version, option wise.
2015 RAM 2500 CC/LB 4x4 CTD
2018 Jayco Talon 413T
B&W Companion
atwowheelguy
Marietta, Georgia
Posted: 01/04/18 11:07pm Link  |  Quote  |  Print  |  Notify Moderator
It's easy to exceed the GVWR on 250/2500 diesel trucks when hitching up fifth wheel toy haulers.
[image]Click For Full-Size Image.
2013 F150 XLT SCrew 5.5' 3.5 EB, 3.55, 2WD, 1607# Payload, EAZ Lift WDH
Toy Hauler: 2010 Fun Finder XT-245, 5025# new, 6640-7180# loaded, 900# TW, Voyager wireless rear view camera
Toys: '66 Super Hawk, XR400R, SV650, XR650R, DL650 V-Strom, 525EXC, 500EXC
tinner12002
Lafayette Ind
Posted: 01/05/18 06:14am Link  |  Quote  |  Print  |  Notify Moderator
I'd find it hard to believe you'll find a toy hauler in the size your looking for that you can tow with your truck and stay within the manuf ratings. Even the lighter ones at 30-34 ft are going to have a pin of 1800lbs or more which doesn't leave you much room for fuel, stuff or passengers. Looking up your truck I see it is only rated to tow 14K for a 5th wheel.
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
