RV.Net Open Roads Forum: Tech Issues: Zamp solar alternative
 > Zamp solar alternative
richy2
Posted: 01/12/18 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
I have a small motorhome equipped with 2 agm group 27 batteries, Zamp external port and 1000 watt inverter. looking for alternatives to Zamp suitcase type solar panels. I have minimal power needs, two or three hours of tv and some led lighting. I do not want to void warranty, so compatibility is important. Thanks for suggestions.
Based on the questions, I'll try to be more clear. I want something portable as in suitcase type not roof mount. The port is sae. Compatibility means working with equipment I have mentioned. Will need controller.
Based on some of the responses, I guess I'm still not clear. All that I need is a portable solar panel to work with a motorhome that is Zamp solar ready, meaning it has a SAE port mounted on side of motorhome. What manufacturers other than Zamp can provide what I'm looking for, hopefully at less cost.
* This post was last edited 01/14/18 07:08am by richy2 *   View edit history
pauldub
North of Seattle
Posted: 01/12/18 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
Do you want portable or roof mount panels?
Almot
out there
Posted: 01/12/18 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
... and another question - what "compatibility"... Though, probably, not a question.
time2roll
Posted: 01/12/18 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
What does a Zamp connector look like?
Is it same as an SAE 12v connector?
Some panels here:
https://www.solarblvd.com/product-catego........lar-panels-systems/12-volt-solar-panels/
Do you need a controller?
How many watts are you looking at? 100w? 500w?
If going big you will need to post the size wire on the connector. I would hope it is #10 but probably #14 or #12.
* This post was last edited 01/13/18 01:27pm by time2roll *   View edit history
675w Solar pictures back up
El Pueblo de Nuestra Senora Reina Los Angeles
Posted: 01/12/18 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Consider carefully if you want to setup, watch over, takedown and store solar panels. Roof mounted avoids all that and works as soon as its light...and you are still snoozing.
2015 Winnebago 2101DS TT & Chevy Tahoe LTZ, 300 watts WindyNation solar - parallel & MPPT, Trojan T-125s. TALL flagpole for USC & historical flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county campgrounds. 14 year Army vet. Bicyclist!
Ralph Cramden
US
Posted: 01/12/18 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
Some panels here:
That's the connector, although the Zamp port installed by most if not all OEM's is typically reverse polarity, so You need to reverse the leads on either the connector your plugging in or the wiring installed by the manufacturer. You also usually need a controller in most cases, as the OEM port is typically just that and wired directly to the battery connection.
red31
Bryan
Posted: 01/12/18 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.solarblvd.com/products/solar........160-watt-foldable-12-volt-solar-panel-2/
scrape the included charge controller and get the grape solar controller @ home depot, contact grape for app to talk with bluethooth controller
https://www.homedepot.com/p/Grape-Solar-........ler-with-Bluetooth-GS-PWM-40BT/207100856
mount the controller inside and then to the outside wall port, wire the portable panel with correct polarity plug and connect to outside port. Extend panel wires with 12g landscape wire/ft from HD to what ya need.
ktmrfs
Portland, Oregon
Posted: 01/12/18 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
x2.
I have 3 of these for my portable setup. works great
2011 Keystone Outback 295RE
Almot
out there
Posted: 01/12/18 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
Not an issue.
Your devices will be running on any 12 VDC power, no matter whether it comes from the battery alone or from battery and solar controller.
If by equipment you mean 2-pole SAE connector, - solar array with a current exceeding the amps rating of this connector, would be too big to be considered a portable. Your wire gauge is more important.
red31
Bryan
Posted: 01/13/18 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
Renogy mc4 to sae adapter
https://www.renogy.com/renogy-mc4-to-sae-adaptor/
