RV.Net Open Roads Forum: Towing: Haul Master
Search only in Towing
Open Roads Forum  >  Towing
 > Haul Master
noonenosthis1
northern california
Posted: 01/13/18 11:23am Link  |  Quote  |  Print  |  Notify Moderator
Anyone use this hitch?
https://www.harborfreight.com/10000-lb-capacity-weight-distributing-hitch-system-67649.html?utm_referrer=direct%2Fnot+provided&utm_referrer=https%3A%2F%2Fwww.facebook.com%2F
We tow a 2017 Cougar 32RES with a 2000 Excursion V10. We don't get much sway but we do get porpoising.
LanceRKeys
Amarillo, TX
Posted: 01/13/18 11:30am Link  |  Quote  |  Print  |  Notify Moderator
I have used one in the past, but on a much smaller trailer (24', no slide). It seemed to work fine, but really needed more drop to level out the trailer just right. I have had really good luck finding used hitches online from people who only used them a time or two and then sold the trailer.
Old-Biscuit
Verde Valley
Posted: 01/13/18 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
So you are NOT using any WDH currently?
9000# trailer.........any WDH is better then none
noonenosthis1
northern california
Posted: 01/13/18 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
We have a WDH. I was thinking of changing it.
SoundGuy
S Ontario
Posted: 01/13/18 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
With the $$$$$ you have invested in a trailer the size of yours do yourself a favour and invest in a quality weight distribution system with integrated sway control - Blue Ox Sway Pro, Equal-i-zer, are just a couple worthy of consideration.
Bedlam
PNW
Posted: 01/13/18 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
Mine from HF works great with a 20’ enclosed trailer weighing about 8000 lbs. The parts are interchangeable with many round bar hitches from the popular manufacturers. I’ve had mine since 2013 and put about 7500 miles a year on the trailer and hitch.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
drsteve
Michigan
Posted: 01/13/18 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
If you're changing it out, get one with integrated sway control. It's less hassle to hook up, and it works better. Husky Centerline TS, Reese Dual cam, etc. 1000# bars might not be heavy enough for that TT.
* This post was edited 01/13/18 07:25pm by drsteve *
1991 Palomino Filly PUP
dodge guy
Bartlett IL
Posted: 01/14/18 06:10am Link  |  Quote  |  Print  |  Notify Moderator
I’m running a Reese Dual Cam with 1200lb bars on my 9200lb loaded trailer. I’m towing with an 02 Excursion with the V10. I wouldn’t think of using any other type of hitch.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
07 Cherokee 32B Dexter EZ Flex
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese DualCam Prodigy brake controller
A bad day of camping is
theoldwizard1
SE MI
Posted: 01/14/18 08:42am Link  |  Quote  |  Print  |  Notify Moderator
The HF is no better and probably no worse than any other WD hitch without additional "features".
"Porpoising" implies too much tongue wait. You might just need to re-adjust the tension on your spring bars for proper ride height. Air spring on the rear axle of your TV would help.
noonenosthis1
northern california
Posted: 01/14/18 10:09am Link  |  Quote  |  Print  |  Notify Moderator
We do have air springs on the Excursion. Our new trailer, 2017 Cougar 32RES must have more weight at the rear with two slides. This is a different feel between towing the 2017 Cougar 31sqbwe (not that I am driving but I feel everything). Yet there isn't much difference in length and weight between the two trailers.
 > Haul Master
