RV.Net Open Roads Forum: Planning for inverter for elec. refrig, while driving
 > Planning for inverter for elec. refrig, while driving
PilgrimStill
Waterproof, Louisiana
Posted: 04/11/18 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
My dual fuel refrig in my 5th wheel doesn't keep things cool enough. I am going to replace it. Dry camping is a seldom done thing; we mostly travel, stopping in RV parks with elec. and water. I want to put a battery and inverter into my refrigerator swap out, so that the refrigerator will stay cold while we are on the road. I don't plan to charge the battery during the day. I'll recharge it in the evening, when connected to shore power. The refrigerator I am considering is the Avanti RA7316PST 2-Door Apartment Size. Supposedly, this draws 15 amps at startup. Will a 2000 Watt Continuous/4000 Watt Peak Power Inverter (Jupiter) connected to a deep cycle battery be sufficient? Any insight is much appreciated.
JimF - a Pilgrim Still
"Preserve Game, Use a Trained Dog"
time2roll
Posted: 04/11/18 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
2000 watt rated inverter should start anything with a regular plug. I recommend sine wave for most items... especially a motor.
I think you could easily use the existing battery in your trailer for this purpose. Small charge on the road is already set up and recharge at the destination would be automatic.
675w Solar pictures back up
near La Cuesta Encantada
Posted: 04/11/18 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
“My dual fuel refrig in my 5th wheel doesn't keep things cool enough.”
Why not avoid all this and repair your current fridge or get a new RV fridge? RV fridges work well.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
Gdetrailer
PA
Posted: 04/11/18 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
15A startup surge is a bit on the high side, most home fridges use the same compressor which is typically 1.1A-1.2A running draw, I measured the surge of my 10 cu ft fridge I used in my TT at about 10A-11A startup surge with .9A run current.
With that said, I would highly recommend not skimping and using a cheapo Harbor Freight inverter..
Instead, spend a bit more and get a BETTER built inverter designed from the ground up to handle the startup surge of a heavy inductive load like a fridge compressor.
I highly recommend a Tripplite PV1250FC which is a industrial MSW inverter built like a tank which is the inverter I used in my conversion.
Right now you can get it for about $235 through Amazon (ship and sold by Amazon) HERE. That is not all that more money than the cheapo HF inverter at $169...
1250W continuous output with an honest 1875W surge for up to ONE HR and 2500W surge for TEN SECONDS!!! No other inverter out there can match what this Tripplite offers.
"Harness your vehicle's battery to efficiently power office equipment on the road or power tools at a work site. Continuously supplies up to 1250 watts of 120V AC power to 2 AC outlets from any 12V battery or automotive DC source. Frequency control locks AC output at 60Hz for operating stability of motor loads. Includes a set of high current DC input terminals for simple permanent installation. Highly reliable large transformer design specializes in powering motors and other inductive loads with high-current startup needs. PowerVerter Plus Inverters acmodate "peak surge" demands by delivering more output power than their continuous rating. Compare the "Continuous" and "Peak Surge" wattage ratings and you'll find PowerVerter Plus Inverters supply up to double their output to easily handle equipment start up and motor cycling requirements. A DoubleBoost feature provides up to 200% of the continuous output for up to 10 seconds providing the extra power needed to cold start heavy-duty tools and equipment. An OverPower feature delivers up to 150% of the continuous output for up to 1 hour. Primary InformationPower Device Type : Power converter Power Device / Form Factor : External Voltage Provided : AC 120 V +/- 5% Voltage Required : 12 V Power Provided : 1.25 kW Input Connector(s) : 2 Output Connector(s) : 2 x power NEMA 5-15 Enclosure Color : Black Width : 8.7 Inch Depth : 9 Inch Height : 7 Inch UNSPSC CodeUNSPSC Code : 39121006 "
It is big and heavy weighing in at 24 lbs..
Also is about 90%+ efficient, the HF inverter is something like only 82%-87% efficient meaning you will get more run time from your batteries..
And even better the PV1250 also has a power save feature called "load sense" which allows the inverter to detect if there is a AC load or not ans the inverter will turn on/off for the AC load demand! Saves a lot of battery capacity!
I would highly recommend that you use very heavy gauge wire, I used 1/0 on mine, fused at 200A and the fuse needs located within 18" of the battery.. You NEED to locate the inverter CLOSE as possible to the batteries, mine is only three feet from the batteries for a total of 6ft of 1/0 wire..
I would recommend getting Extra flexible 1/0 wire, you will need to order this since Home Depot and Lowes only stocks building wire which is NOT real flexible. Welding wire can be used which is extra flexible but not cheap for this size..
There are some mail order outfits which do sell at good pricing..
1/0 Entertainment/stage lighting cable for $2.35 HERE which is a deal compared to 1/0 welding cable or even building wire..
Then you run normal Romex wire from the inverter to the fridge for the 120V..
You NEED to consider some GOOD batteries, I used a pair of 6V GC batteries wired in series to get 12V for my setup, gives me about 20hr-24hrs without needing to recharge and since we run light on other battery draws it works great for us.
Sam's club or Costco is a great source for 6V GC batteries..
2oldman
Salton Sea
Posted: 04/11/18 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
PilgrimStill wrote:
..connected to a deep cycle battery be sufficient?
One battery? Not sure that will handle the startup surge without a significant voltage drop.
Ivylog
Blairsville, GA and WPB, FL.
Posted: 04/11/18 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
I'm powering a 21 cuft Whirlpool with a 1000W PSW inverter. While running it only draws 8 amps DC...96 Watts. I can boondock 24 hours with two batteries before needing to recharge. You do not need that big an inverter and one battery is plenty for 12 hours...you can go 12 hours without it running if you keep the door closed.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
How I tow.
Towing a Prius without a dolly
How I spend the winter.
Gdetrailer
PA
Posted: 04/11/18 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
The inverter the OP specified is a Harbor Freight MSW inverter, it WILL take most if not all of that cheap import inverter and may even smoke it in the process.
With your 1000 PSW inverter, it may have a bit more quality parts in it and may be able to handle the inductive kick of the compressor.
most cheap Chinese import MSW inverters will let out the smoke packets when treated to heavy induction motor kicks..
When it comes to cheap stuff, it is a go big or go home thing, super size it to make sure you have enough..
But personally, in cases like this, I like to go with heavy duty quality type overkill like the Tripplite I mentioned..
theoldwizard1
SE MI
Posted: 04/11/18 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
If you are on shore power overnight and you NEVER open the door to the refrigerator until you are plugged back into shore power and you are on the road for less than 10 hours per day, you really do not need an inverter.
Now that I said it, I would get a name brand 2000/4000 pure sine wave inverter and TWO 6V golf cart batteries. Samlex makes a nice inverter/charger. I like it because of it simple wiring. Get rid of your old converter (keep the DC distribution panel and wire it directly to you house battery bank). The shore power connects to the inverter/charger and there is a built in transfer switch so you use shore power when connected and inverter power when not connect WITHOUT OUT HAVING ANYTHING TO SWITCH ! It will also accommodate a generator and input from solar panels.
You really should have your house battery bank hooked to your tow vehicle battery via a DC-DC charge. Read this regarding charging a house battery from a vehicle alternator.
DC-DC battery charging
EDIT : Samlex 1200W/3600W inverter/charger (no separate generator input; plug the generator into the shore power plug)
PilgrimStill
Posted: 04/11/18 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Awesome input! Thanks. I will do some research on all those suggestions. I get the inference that a PSW is preferable to a MSW. True?
Gdetrailer
PA
Posted: 04/11/18 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
Not all inverters have the same quality in engineering and parts and that includes PSW inverters.
PSW generally will provide a cleaner waveform that looks a lot closer to what your commercial utility provides and for SOME equipment it is better for.
However, not ALL equipment "needs" psw, in fact if it has a switching powersupply (like a computer or TV) there is zero reason to buy PSW because those supplies are designed to take pretty much any badly distorted waveform and keep ticking..
The problem starts when you buy the cheap stuff, even cheap PSW inverters may not work well, the reason for that is it takes more parts and engineering to properly form a perfect sinewave. More parts and engineering makes the inverter cost more.
MSW gets a bad rap because of the cheap imports like the HF stuff, not all MSW inverters are bad..
Really cheap MSW inverters can often make the induction motors run hotter than they would on PSW and some just simply cannot even start an induction motor.
There are high quality MSW inverters, you will pay more than even some of the low cost PSW inverters.
To get any inverter of sufficient quality that will be able to deal with the inductive startup kick of a fridge compressor you WILL want to put the money into a good one the first time..
Very few inverters publish the surge time, Tripplite is one of the very few that does.. Most do not and the reason for this is many of those inverters that surge current is milliseconds.. Inductive loads can have a startup surge of several seconds..
Induction motors can present a very large inductive voltage spike back INTO the inverter, cheap inverters (MSW AND INCLUDING LOW COST PSW) may not be able to handle these voltage spikes.
Sure, you can over buy on a cheap inverter like a 2000W to get around the short surge time but you are not going to be happy when that inverter fails at the wrong time due to it seeing the inductive voltage kick back.
It is your rig so do what you want.
