RV.Net Open Roads Forum: Class A Motorhomes: MH Correct Vacuum Line Actuator Connection?
 > MH Correct Vacuum Line Actuator Connection?
TC&Z
Atlanta, GA USA
Posted: 04/15/18 09:51am Link  |  Quote  |  Print  |  Notify Moderator
We have a 2007 Winn Voyage 38J on a Workhorse chassis. We had dash AC problems and got it serviced. Shop says they also had to replace an air box actuator. Good news is air is cold now but doesn't come out where I expect it to. I am wondering if they connected the actuator back correctly. It is a 3-position actuator on driver side of engine just under the wind shield deck that has 2 hoses attached to it, a red one and a white one. Currently the red is on the end, and white on the side of the actuator. Can anyone confirm if this connection matches theirs? I can try swapping and see if it improves but hard to get to, I don't want to do it unless I know that's the problem. I can also try to call Winn tech service but concerned they may not know this detail and send me to Workhorse. Thanks
dougrainer
Carrolton, Texas
Posted: 04/15/18 11:52am Link  |  Quote  |  Print  |  Notify Moderator
1. Workhorse does NOT install the Dash AC system. Winne(OEM) installs the controls. They are aftermarket NOT a Workhorse Part. The only thing the chassis makers supply is the Compressor and those hoses and the Condenser.
2. Odds are you have a Evans Tempcon system. This is the link for their systems and troubleshooting. Doug
http://www.evanstempcon.com/tsg_hvac.php
turbojimmy
New Jersey
Posted: 04/15/18 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like it went in for one problem and came out with another. I'd have the shop make it work like it should at their cost.
1984 Allegro M-31 (Dead Metal)
TC&Z
Atlanta, GA USA
Posted: 04/16/18 07:00am Link  |  Quote  |  Print  |  Notify Moderator
Agree it would be at no cost but there's our hassle factor of taking MH back and dealing with them. If it is easy it is worth it to me to do it myself, plus I learn something too.
TC&Z
Atlanta, GA USA
Posted: 04/16/18 07:39am Link  |  Quote  |  Print  |  Notify Moderator
With more research I found this helpful Winn Service Tips link regarding my situation. We have the rotary control style system. Appears my vacuum hoses are connected properly.
Winn Service Tips - Dash Air
TC&Z
Atlanta, GA USA
Posted: 04/16/18 07:40am Link  |  Quote  |  Print  |  Notify Moderator
deleting duplicate entry
turbojimmy
New Jersey
Posted: 04/16/18 07:47am Link  |  Quote  |  Print  |  Notify Moderator
My concern at this point would be that they installed the incorrect actuator and it's not getting the right signal from your controls.
TC&Z
Atlanta, GA USA
Posted: 05/11/18 06:39am Link  |  Quote  |  Print  |  Notify Moderator
I posted this. After extra careful inspection I found that the vacuum lines to the actuators in the engine compartment had what looked like heat ozone deterioration, they were brittle and crumbly and were leaking. Our rig these lines are small hard plastic, about size of a coffee straw, each a different bright color. I replaced them with automotive rubber vacuum line and all is good now.
turbojimmy
New Jersey
Posted: 05/11/18 06:48am Link  |  Quote  |  Print  |  Notify Moderator
Awesome! And thanks for not leaving us hanging without a resolution!
