RV.Net Open Roads Forum: Beginning RVing: Roll-up Canopy Replacement
 > Roll-up Canopy Replacement
TrailLite30
Palm beach
Posted: 05/15/18 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Hello, I just recently purchased a new canvas for my roll up canopy off of Amazon, I plan on installing it this weekend but have never done it before and was wondering if anyone has any pointers or suggestions to make this process easier, it's ALEKO RVFAB18X8BLUE24 Retractable RV or Home Awning 18 x 8 Feet Blue Fade . Installing the top part where it attaches to the camper looks pretty straightforward but the aluminum roll-up looks like it might be tricky.
the bear II
Torrance CA.
Posted: 05/15/18 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
There are lots of videos on YouTube be sure to watch them.
The most dangerous step is the spring tension release and tensioning.
Two people are needed three are preferred and two to three ladders
TrailLite30
Palm beach
Posted: 05/15/18 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
Oh boy ! I will definitely watch the videos, may have an extra buddy possibly 2 but we only have 1 ladder : (
garyemunson
Reno, Nevada
Posted: 05/16/18 06:35am Link  |  Quote  |  Print  |  Notify Moderator
Try to borrow a second ladder. 2 people can do it but 3 cuts the time in half.
fitznj
nj
Posted: 05/16/18 08:24am Link  |  Quote  |  Print  |  Notify Moderator
I did this 2 years ago - never again - the spring tension on the roller can be lethal - there is a lot of energy stored in the spring when extended - wear eye protection and heavy gloves.
It was a really tough to get the right tension back into the roller;
Gerry
TrailLite30
Palm beach
Posted: 05/16/18 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Fitz ! I will definitely wear eye protection, were there any special tools you used to make job easier?
fitznj
nj
Posted: 05/16/18 10:08am Link  |  Quote  |  Print  |  Notify Moderator
There is a special tool to wind the spring up but I used a strong screw-driver placed through the hole on the end of the roller - this is the DANGEROUS part - my hand slipped and the screw-driver went flying - missing my head by a couple
of inches - I'm sure that is a safer way to do it.
If you have torsion springs on your garage doors - it's similar.
dodge guy
Bartlett IL
Posted: 05/16/18 10:30am Link  |  Quote  |  Print  |  Notify Moderator
Just roll the awning out. Then the pawl Inside will hold the awning just like it does when you have it when camping. Just loosen the top reinforcement bars to keep the awning material slack then tighten them. Then you can cut the old awning out and slide the new one in. Very easy. Now if it’s an electric awning then that’s a bit different and you need to hold the roller with a screwdriver to keep it from unwinding. Otherwise it’s similar.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
07 Cherokee 32B Dexter EZ Flex
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese DualCam Prodigy brake controller
A bad day of camping is
bukhrn
Lanexa, Va
Posted: 05/16/18 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
Or, you could do as some of us have done, pay someone else to do it, regardless of cost, it could be well worth it.
I still have all my finger and NO screwdriver stuck in my eye, and the awning works perfectly, looks great, and tension is perfect.[emoticon]
2007 Forester 2941DS
2014 Ford Focus
campigloo
Baton Rouge, La
Posted: 05/17/18 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
I helped a friend do his. I would not try it with less than 3 people and 2 ladders.
Definitely watch the videos. Just take your time, be careful and it will work just fine. There really isn’t much to it, just really bulky and floppy. Use lots of spray silicone.
