RV.Net Open Roads Forum: Tech Issues: Riddle me this, inverter
 > Riddle me this, inverter
Byrogie
Whisper Valley Alberta
Posted: 05/16/18 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Xantrex Freedom 2000 watt inverter
Trailer is 50 amp service. 4x6 volt GC2, fat wires.
Hooked up to main trailer power via inverter outlet, extension cord and adapter.
500 watt coffee pot/ 800 watt hair dryer trips inverter outlet. These work fine if plugged directly to the inverter.
All other stuff works fine in trailer, TV, charging phones, ceiling fan, etc.
My ac tester shows good power, but trips inverter outlet when I press GFI test button.
Will eventually hardwire the inverter, will it work properly then?
BFL13
Victoria, BC
Posted: 05/16/18 08:58am Link  |  Quote  |  Print  |  Notify Moderator
You need to turn off the converter, fridge, and water heater from 120v while using the inverter with the shore cord plugged into it as "whole house".
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
time2roll
Posted: 05/16/18 09:04am Link  |  Quote  |  Print  |  Notify Moderator
You are plugged into the inverter GFCI outlet right?
So the GFCI test trips off power... sounds normal to me.
675w Solar pictures back up
dougrainer
Carrolton, Texas
Posted: 05/16/18 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Try running a GROUND wire from the Inverter Ground wire case connection to the Ground/frame of the RV. Inverters are supposed to be grounded to the RV. The Battery neg is not enough. Doug
ScottG
Bothell Wa.
Posted: 05/16/18 09:18am Link  |  Quote  |  Print  |  Notify Moderator
X2, that's what it's supposed to do when you press the "test" button.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
MrWizard
Traveling
Posted: 05/16/18 09:29am Link  |  Quote  |  Print  |  Notify Moderator
Outlet is supposed to trip, when you press the test button
If gfi trips when plugging the trailer into inverter via cords and adapters, there is a power leak to ground, like an electric heating element
Or do you mean inverter overload trip
Overt load mad too much stuff using inverter power
Be sure fridge is on lp unit on automatic,
Wh soon lp for off
Converter turned off, no such thing as free power, charging your batteries from your batteries, it's just one big power drain loop
It's a common thing to forget about power hogging drains when first getting an inverter
Radiate The Happy
1997 F53 Bounder 36s
BFL13
Victoria, BC
Posted: 05/16/18 09:30am Link  |  Quote  |  Print  |  Notify Moderator
My 2000w Vector MAXX inverter manual says the chassis ground is just for reducing interference on the television, etc.
The manual warns not to run the chassis ground wire around to the input neg terminal of the inverter, but to run it directly to the frame.
With inverter to battery, you don't need the battery to be grounded to the frame at all, but it usually is of course in an RV
Byrogie
All ac breakers are turned off except for receptacles.
Inverter is grounded to frame.
Devices work fine plugged to inverter outlet directly or with extension cord.
Trips inverter GFI outlet when plugged to trailer receptacles.
I have used whole house with old trailer and different inverter. Everything worked properly.
Everything works fine if using 2000 watt generator.
time2roll
Posted: 05/16/18 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Have you plugged into a home or pedestal GFCI? Does that work?
Often the fridge or converter is connected to the convenience outlets. Either can cause GF issue. Start by unplugging the fridge... usually a plug in the exterior service compartment.
* This post was edited 05/16/18 09:52am by time2roll *
MrWizard
Traveling
Posted: 05/16/18 09:43am Link  |  Quote  |  Print  |  Notify Moderator
Bad adapter ?
Miss wired cord ?
