RV.Net Open Roads Forum: Tech Issues: very low coolant
 > very low coolant
anon125
anywhere
Posted: 06/13/18 08:16am Link  |  Quote  |  Print  |  Notify Moderator
our 2006 itasca witha a gas engine has been parked for a couple of years.
we wanted to drive it a mile or so to get it serviced - engine all change etc.
we noticed that the yellow coolant was very low. there is nothing on the floor, does this stuff evaporate?
will it do any harm to drive it to the servicing folks?
we will have a look to see if the hoses are okay.
thanks all
2006 Itasca sunova 29r
wolfe10
Posted: 06/13/18 08:19am Link  |  Quote  |  Print  |  Notify Moderator
If you are going to change the coolant, just add water-- distilled water best, and a good use of $.97.
If not going to change coolant, determine what is in there and buy some of it.
I would NOT drive with very low coolant level.
Now, if the level in the overflow reservoir is all that is low, no worries. BUT, you need to remove the radiator cap to verify that the level in there is OK.
Brett Wolfe
2003 Alpine 38'
SAR Tracker
Central Oregon
Posted: 06/13/18 08:43am Link  |  Quote  |  Print  |  Notify Moderator
wolfe10 wrote:
....BUT, you need to remove the radiator cap to verify that the level in there is OK.
Only do this on a cold engine. Steam burns hurt. A Lot!
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
Death Valley!
Posted: 06/13/18 08:48am Link  |  Quote  |  Print  |  Notify Moderator
Check all the RV systems too. Two years is a while. Your drive to the repair shop would be good for sloushing the water/bleach mix around in the fresh water tank.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
ksg5000
Oregon
Posted: 06/13/18 08:56am Link  |  Quote  |  Print  |  Notify Moderator
If it were me I would add water and then tell the service personel that your coolant was low so they can test the system.
Kevin
ScottG
Bothell Wa.
Posted: 06/13/18 09:00am Link  |  Quote  |  Print  |  Notify Moderator
X2!
DONT drive it with low coolant.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
time2roll
Posted: 06/13/18 09:13am Link  |  Quote  |  Print  |  Notify Moderator
How low is low?
Is it the expansion/overflow reservoir that shows low? Low here is fine to drive unless it is totally empty then check the radiator.
Is the radiator actually low as you look into the tank? If you see some coolant in the radiator it is probably fine to go a couple easy miles to the shop. Otherwise top it off with distilled water or 50/50 coolant if you have the right stuff.
675w Solar pictures back up
anon125
anywhere
Posted: 06/16/18 08:10am Link  |  Quote  |  Print  |  Notify Moderator
thanks everyone for your help
wolfe10
Posted: 06/16/18 08:27am Link  |  Quote  |  Print  |  Notify Moderator
So, was the radiator or just the overflow reservoir low???
anon125
anywhere
Posted: 06/16/18 08:32am Link  |  Quote  |  Print  |  Notify Moderator
good question!
we have not yet started the engine.
it is low in that big round overflow reservoir.
maybe when we start the engine it will go back to normal
thanks
 > very low coolant
