RV.Net Open Roads Forum: Tow Vehicles: Does your 6.4 Hemi eat lifters?
Search only in Tow Vehicles
 > Does your 6.4 Hemi eat lifters?
ScottG
Bothell Wa.
Posted: 07/11/18 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
This is a little bit of a stretch for tow vehicles but since the Ram's have the 6.4 Hemi option it kinda fits.
I have a Challenger 392 SRT with the 6.4 and it developed a tick at 24K miles (believe it or not, it's been babied). From my research before buying, this engine does not normally suffer from the infamous "Hemi tick" that the 5.7 does.
My tick ended up being one badly worn lifter. While they were in there, they found two more on the opposite bank that we're also worn. Cam was inspected and found to still be fine only because we caught it early. I'm told that sometimes this takes out the cam as well on this eng.
Dodge ended up replacing all 16 lifters under warranty (and had it three weeks because there were 5000 lifters on B/O).
The truck has a very different eng tune but has anyone heard of or had lifter issues with their 6.4?
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Posted: 07/11/18 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
I hope I don't!!
Only 5k miles on the wifes new SRT Charger and the main reason we bought a new one (other than it's cool looking and performs like a car 2x it's price) is because our 06 has been for all intents and purposes Bulletproof.
I don't get on the SRT forums much but from what I have, I don't recall it being a prevalent issue, the "hemi tick" on the newer vehicles
03 Arctic Fox 860
07 Dodge 2500 deezul
Turtle n Peeps
California
Posted: 07/11/18 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, weird!
Sounds like soft rollers to me. I wonder if a contractor screwed up? It would be interesting to know what they Rockwell at?
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
ScottG
Bothell Wa.
Posted: 07/11/18 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
Seems like it has to be a hardness issue. The new lifters have a revision of "AC" so something has changed but the dealer couldn't tell me if they were improved. It was the lifters at the ends of the head that wore. Hope it isn't an oiling issue..
Decided I will get rid of it in 2020 and will trade it for new RAM/Cummins. By that time I will have had my fun [emoticon]
STBRetired
I-80 and I-55
Posted: 07/11/18 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
Be sure that you are using the proper weight oil and changing it as recommended. Have not heard of any rampant lifter failures in 6.4 HEMIs.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
dodge guy
Bartlett IL
Posted: 07/11/18 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it’s an issue, but a very small one and only affects certain engines more than others. And there is no set reason for why it affects certain engines and not others of the same style.
Best to just keep an ear out and listen, when it starts ticking take it in!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
07 Cherokee 32B Dexter EZ Flex
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese DualCam Prodigy brake controller
A bad day of camping is
Shaneo
Maryland
Posted: 07/11/18 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
I don't post a whole bunch, really enjoy reading through the forums though. This particular topic got my blood pumping :-)
I have a 2016 Ram 2500 6.4 Hemi w/ 4.10 rear end. All oil changes have been through the dealer along with other maintenance items. I am on my THIRD set of lifters. Each time replacing cams and all lifters. The dealership has never been able to pinpoint the specific cause of the problem.. I will be taking it in again during the August/Sept. time frame because the rattling has returned. I will have discussions with the dealer on what can be done through Ram, I don't have high expectations they will be willing to help though.
I am not towing heavy and it is a daily driver truck. I have right about 53,000 miles....... I 'm counting down the days until I can just leave this truck at the dealership and drive a Duramax home.
Me, the Wife and two little guys
2016 Ram 2500 CC, 6.4 Hemi
2016 Eagle HT 29.5BHDS
Lynnmor
Red Lion
Posted: 07/11/18 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
At a minimum, I would change both the type of oil and who does the changing. Chances are that your dealer service is as dumb as mine.
ScottG
Bothell Wa.
Posted: 07/11/18 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
It isn't oil, I use the correct 100% 0-40 synthetic oil and only OEM SRT oil filters.
Shane, your scaring me! If this pops up again it will be a gonner!
Shaneo
Maryland
Posted: 07/11/18 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
I'm sorry to shed the negative light, this issue has plagued me for the past ~20,000 miles. We are not far from getting rid of the truck.
I do have a friend, 2014 Ram 6.4 w/ 4.10s, basically the same truck with 75,000 without a hint of problems. It just seems I drew the short straw. I enjoy the truck and appreciate the capabilities it brings to the table without the extra cost of a diesel, but this issue has caused me to question the motor.
