RV.Net Open Roads Forum: Fifth-Wheels: Touch up Paint
 > Touch up Paint
accuratekarla
holland
Posted: 07/11/18 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
I have an Arctic Fox 5th wheel.
We had someone back into it and scratch the back corner piece. Does anyone know where to get touch up paint for the scratch?Luckily no dents!
Thanks!
BobKrogstie
Posted: 07/11/18 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
Try the manufacturer:
Northwood Manufacturing Customer Service
Bob and Natalie
2008 Grand Junction 37QSB
2009 Dodge 3500DRW Big Horn 4X2/CC/LB/CTD/4:10/Auto
donn0128
Pronounced Ore-gun
Posted: 07/11/18 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Call Northwood and get the paint code. Take the code to NAPA dealer or a local auto paint dealer and have them make you up a couple of spray cans.
Super_Dave
Harrisville, UT
Typically, the manufacturer can give you the paint codes and local paint shops can mix the touch up paint.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
path1
Varies with weather
Posted: 07/11/18 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
If white krylon satin white matches my 25w perfect. Ace hardware believe it or not.
Krylon. 2420 satin white.
Myself I tried to get the gray at bottom. Never did find out. Northwoods forum also has some info, couple years ago. They charge after free period or used to.
path1
Varies with weather
Posted: 07/12/18 10:28am Link  |  Quote  |  Print  |  Notify Moderator
OP my post just above... hold tight. Going to trailer today. Will double check to confirm. I might have my paint mixed up with paint for small class c.
One of the pit falls of 2 rv's. (And dragging jock back and forth between them.
path1
Varies with weather
Posted: 07/12/18 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
Yes that's the right paint. At least for mine. Arctic white is what I call it.
 > Touch up Paint
