RV.Net Open Roads Forum: Turn on my A/C and it just goes hummmm...
 > Turn on my A/C and it just goes hummmm...
Damdifino
Comfort, TX
Posted: 09/06/18 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
I've been having A/C anomalies this summer, which I thought I'd fixed. First, it tripped the breaker, so I cleaned the coils, changed the circuit breaker, and it ran good for a couple of weeks. But now, I turn it on and it just hums, like it's struggling to start up. What should I look at?
2013 Casita 17' Freedom Deluxe
2014 Arctic Fox 22H.
2009 Toyota Land Cruiser URJ200 Series
72cougarxr7
Northern NY
Posted: 09/06/18 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
I had a similar issue with my Dometic ac, ended up being a "run capacitor". Found one on Amazon for $10 shipped to my door. Working great now.
Just put your model number into one of the online parts places and find the part number.
Shop around with that part number, Amazon, Ebay etc. You will find a good price that way.
newman fulltimer
louisiana
Posted: 09/06/18 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Need a new fan motor
ScottG
Bothell Wa.
Posted: 09/06/18 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
Exactly what mine did when the start cap died.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
lostbytes
Was lostmarbles years back on here....
Posted: 09/06/18 10:09pm Link  |  Quote  |  Print  |  Notify Moderator
Yup. You not getting enough help from the capacitor. You'll need an soft start capacitor. It used to be you'll need an hard start capacitor but the newer soft are a little easier on the motor windings. Older ac usually needs some extra help because they wear out and need more wattage to get going. Just get one and hook it up piggy back to the original capacitor. Look up on YouTube/Google search about how to hook one up on an RV ac.
https://www.loveyourrv.com/installing-hard-start-capacitor-into-my-rv-air-conditioner/
Here's one on hard start.
If one of those original caps is bulging then it need to be replaced first. Then try ac. If problem not solved, then add soft start.
marcsbigfoot20b27
Phx
Posted: 09/06/18 10:56pm Link  |  Quote  |  Print  |  Notify Moderator
Not enough info.
Does it hum and no air blows?
Does it hum and air does blow?
Camreal
Kerrville, Tx
Posted: 09/07/18 06:00am Link  |  Quote  |  Print  |  Notify Moderator
If you can get to the fan turn it by hand and if its not turning free the bearings need lubricating. Some times you can free them up with spray.
ksg5000
Oregon
Posted: 09/07/18 06:08am Link  |  Quote  |  Print  |  Notify Moderator
Symptoms sound like low power or dead/dying compressor. Check your power source and make sure it's good and as others have said inspect your capacitors.
Kevin
Wherever I happen to park
Posted: 09/07/18 06:49am Link  |  Quote  |  Print  |  Notify Moderator
Two suspects..
First you said it "Just goes HUMMMM" does it blow air (Assumign not) spin the blower or fan (Remove top cover you should be able to spin the fan) Power off.
Does it spin freely,, or is it hard to turn
Hard to turn bearings sized up replace blower motor (if compressor works)
Spins freely replace start/run caps.
Same for compressor if it's not working replace start/run caps
You might also measure voltage to motors.. Make sure the blower is getting power control board issues (IE: Bad relay) can prevent the blower from blowing. (Same applies to the compressor from compressing). but odds are bearing failure or start/run cap failure
ALL TESTS except power measurement are POWER OFF (I mean trip the breaker manually (turn it off) power off. The voltage test have a partner turn the A/C on and off after you hook up the leads.
Home is where I park it.
Chris Bryant
Arden, North Carolina
Posted: 09/07/18 11:58am Link  |  Quote  |  Print  |  Notify Moderator
It's because it doesn't know the words, obviously.
Seriously, the question asked, does it blow air? I would guess hum is compressor running and blower isn't starting, which would point to fan run capacitor (blower does not use a start capacitor), next bad motor.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
