RV.Net Open Roads Forum: Lights flickering, ac having a hard time cutting on.
 > Lights flickering, ac having a hard time cutting on.
melissajean0
Earth
Posted: 09/13/18 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
All of our lights are flickering when I try and turn them on. And most of the time they're barely even coming on. When I flick the living room AC on it comes on fine. However, when I cut a light on (whether it's in the living room, bathroom, outside light, etc.), the ac cuts off. In your opinion what is this most likely to be caused by? I need to know where to start. Additionally, we are plugged into a box outside and have been for months. Everything else, such as plugged in items and our bedroom ac seem to be working fine.
Husband: Jeremy; 1 Springer Spaniel; 1 Toy Schnauzer
F350 SD 4x4
Ford Edge
2008 Forest River Sandpiper
AL, AZ, AR, CO, FL, GA, IL, KY, LA, MS, MO, NM, TN, TX, UT, WY, OK, KS
London, UK, Ipswich, UK.
Executive
Posted: 09/13/18 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
Because your issue is with the lights my first guess was a bad/shorted switch. However, if it's ALL your lights, I'm assuming they are controlled by other switches. Please verify that. The next guess is going to be a bad/loose wire in the breaker panel. I would NOT turn on the AC until you find the problem. AC units don't like low voltage when they first come on. No sense in adding to your problem. Start by checking your light switch for a bad wire/switch. Is it warm after you've had the lights on for a bit? Ditto for the breaker. Are all your lights on the same breaker in the box? Finally, even though you've been hooked up to the pedestal for months, are you sure you're getting 120V from the pedestal. Verify that also....let us know how savvy you are electricly. We don't want anyone getting fried trying to 'fix' a short....Dennis
EDUCATION IS IMPORTANT, BUT CAMPING IS IMPORTANTER!
Dennis and Debi Ten Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
melissajean0
Earth
Posted: 09/13/18 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, the lights are all controlled by their own switches. Living room switch for living room, bathroom for bathroom, etc. The AC is kicking on by itself. I can't get the lights on to see if anything is warm regarding them. But I've had to reset the breaker before with the ac (ran ac & hair dryer at the same time w/out thinking) and nothing else was ever warm besides that 1 ac breaker. I don't know anything about electricity. My husbands knows a little, but not much.
ScottG
Bothell Wa.
Posted: 09/13/18 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
Check your 12V systems voltage, especially when the lights act up.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
pianotuna
Regina, SK, Canada
Posted: 09/13/18 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
check the battery voltage. When plugged in it should be at least 13.2 volts.
Regards, Don
Mandalay Parr
Phoenix, AZ
Posted: 09/13/18 11:42pm Link  |  Quote  |  Print  |  Notify Moderator
I would check all connections on your power distribution panel. Get an experienced electrical
person to help you.
I will give you phone support if you call me.
I am an experienced troubleshooter.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
fj12ryder
Platte City, MO
Posted: 09/14/18 07:07am Link  |  Quote  |  Print  |  Notify Moderator
Most of the lights are likely 12V and if your converter isn't working properly you'll run down the battery and the lights won't be very bright, and if the battery gets low enough you'll have no lights. The thermostat is also most likely 12V which would explain why your AC quits when you use the lights.
As was recommended check the voltage at your battery. My guess is that your converter isn't putting out enough voltage to charge your battery well enough. Your battery could be toast by now, and if you don't act quickly it will definitely be toast. Depending on your setup you could get by with a new converter but you'll have to check to see what you have.
I discovered all this first hand just a couple days ago. Post back when you have checked your voltage at the battery.
Howard and Peggy
"Don't Panic"
wra
Posted: 09/14/18 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
When you check your breaker connection, don't forget to check the common connection (at the outside plug and breaker box). When checking the 12 volt side, be sure to clean the negative connections (at the battery and converter). Since all lights are affected, the negative side is more likely the culprit.
D.E.Bishop
Eagle Rock, CA
Posted: 09/14/18 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
More likely it is the hot but basic electricity aside, it acts just like the converter is shot.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
95 Suzuki Sidekick 4X4
Stowmaster 5000
melissajean0
Earth
Posted: 09/14/18 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
My husband got home and figured out it was the battery. The battery was pretty old at 6 years I guess. Shrugs, idk.
