RV.Net Open Roads Forum: Fifth-Wheels: WINTERIZE
 > WINTERIZE
abc40kids
Dale City,Virginia
Posted: 11/06/18 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Still using my camper for Thanksgiving and it looks like we have a few nights coming up where it will dip down to like 28 for a few hours during the night. Should I just winterize it to be safe and just re-winterize after my Thanksgiving trip? Thanks, Jeff
* This post was edited 11/06/18 02:31pm by abc40kids *
Jeff,Julie,Amber,Brandon,and Casey and Winston ( our 5 year old Golden ) and Bruno the Pug. We now have an English Cream, white Golden Retriever as well.
2015 Keystone Montana Mountaineer 356TBF
2005 Chevy duramax dually
donn0128
Pronounced Ore-gun
Posted: 11/06/18 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
Simply blow out the water lines, pour a bit of antifreeze in the traps. That should be fine for a few nights and take less than an hour of time.
gbopp
The Keystone State
Posted: 11/06/18 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
Get a RV Blowout Plug.
It's quick and simple.
jfkmk
NJ
Posted: 11/06/18 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Ive camped in the low 20s without winterizing and had no issues. You should be fine.
bpounds
Senile, er I mean
Posted: 11/06/18 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
If you can, run the heater at its minimum setting. Assuming you have a way to get power. I also camp in lower temps than you're expecting, and as long as I keep the heater at 55 degrees, and the days warm up a bit, all is well.
If you cannot let the heater run, I would not risk letting it sit with no heat.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
near La Cuesta Encantada
Posted: 11/06/18 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
Sealed underbelly? With your adequate batteries and a recharging method, run the heater at 52-54F. At those outside temperatures you should be fine.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
Posted: 11/06/18 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Oh! And crack all cupboards open about an inch. All of them.
scbwr
North Ridgeville, OH
Posted: 11/07/18 06:09am Link  |  Quote  |  Print  |  Notify Moderator
I've been in those temps when we had our travel trailers (Sunline, Winnebago Minnie) and never had a problem. I would open cabinet doors where I knew there were water lines running behind, near or in the cabinets and leave the furnace on overnight. In some cases, if it was getting below freezing for several hours, I would disconnect the fresh water hose.
If you're really nervous about it, just blowing out the water lines is very easy but you have to bypass your water heater unless you want to drain it....which wouldn't be necessary for a few hours of below freezing temps.
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
Dave H M
IL
Posted: 11/07/18 07:02am Link  |  Quote  |  Print  |  Notify Moderator
I can see it now. Hey, those guys on the internet said I did not have to winterize!!
Seems it depends on what the weather man is gonna send down the pike.
I think you will be OK if Murphy does not bite you know where.
djousma
SW Michigan
Posted: 11/07/18 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Yea, if in 20's overnight, turn the heat on 50 or so. This past spring I camped in early April, and had a night that got to 25. The water hose and spigot froze overnight, enough that there was no water flow. If a 5/8" water hose can freeze that quickly, then a 1/2" pex line will freeze that much quicker if the trailer isnt kept above freezing.
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
2017 Forest River Cardinal 3850RL
 > WINTERIZE
