I need to have a new double pivot hitch installed for a 13,500 lb GVWR toy hauler. I'll probably never exceed 11,000 lbs however. I've seen the Reese and Lil' Rocker hitches, but the most convenient installation for me is with an installer who installs Valley Industries hitches. His is rated at 22K and is more expensive than the Lil' Rocker, but less than the Reese. Can I get any comments on the brands I've mentioned and more specifically the Valley Industries product. Also, Valley Industries has a patented under-bed system where the mounting rails are installed between the bed and the frame, leaving next to nothing visible in the bed when the hitch is removed. Any comments? Thanks in advance.
I can't say anything about the Valley - I have the RBW Lil Rocker and am extremely pleased with it.
It was quite a bit less expensive than the Reese but I didn't want to make my decision based solely on price because "you get what you pay for" and I didn't want to compromise on such a vital component. So, I did a lot of research and on this and other forums to get feedback and opinions from owners of both brands.
I found that both brands were spoken of very highly by those who owned them, but I think the thing that finally persuaded me was the simplicity of the RBW mechanism. When it latches there is a solid bar that slides across behind the king pin and when that bar is closed there is absolutely, positively NO WAY that the pin is going to come out. I put a white paint mark on the middle of the slide bar and on the lower flange of the king pin so I can visually see that everything is in its proper place.
Regards,
Dave
98 Dodge 12V CTD QC White/Driftwood 2WD 5SP LongBox 4.10LS Cooper 265/75R16E Tabbed KDP PACBrake Jordan Ultima 2020 RBW Li'l Rocker 2002 Layton 237 1971 VW Beetle 1957 Panhead
B&W/Companion hitch no slider
http://www.turnoverball.com/companion/index.htm
http://turnoverball.com/companion/
Valley Industries
http://www.valleyindustries.com/fifth_wheel_hitches.html
http://www.valleyindustries.com/new_products.html
http://www.valleyorders.com/public/applookup.html << with power roller base
Air Hitch:
http://www.advancedairhitch.com/
Craig Kaplenski - President
Uses Reese 22K head
Has slide eliminator - 2 plates with multiple holes - moves king pin behind axle
My wife used to give me $1.00 each workday for lunch. After a long argument, I won. Now she gives me $5.00 every Monday.
"On any given Friday night, more kisses begin with Miller Lite than Kay.".
