RV.Net Open Roads Forum: Fifth-Wheels: Towing Behind Your 5er
 > Towing Behind Your 5er
Chelsea, Michigan, USA
Posted: 11/14/02 10:51am Link  |  Print  |  Notify Moderator
Does anyone have any experience with towing something behind your 5er. I would like to tow a small single place flatbed motorcycle trailer, weight is approx. 350 pounds. What do you think ?
Thanks
Dennis
Sunnybrook 31BWFS
Clipper
Campbell River, BC, Canada
Posted: 11/14/02 10:55am Link  |  Print  |  Notify Moderator
I tow a 17.5 ft boat behind my 25 ft 5th wheel and have had no problems whatsoever. You need to be aware of where you can and cannot go due to the impossibility of backing up more than a few feet but other than that, no issues.
A small trailer will be pretty hard to see when you're underway so that might be an something to be aware of. Also make sure it is legal in your area.
texatDurango
North Texas
Posted: 11/14/02 11:33am Link  |  Print  |  Notify Moderator
I just built a single rack to carry a Yamaha 250 (310 lbs)on the back of my fifth wheel using a class 4 hitch. Hitchhiker engineers tell me I'm good up to 800 lbs on the rear of my particular model before kingpin weights would be affected. If your trailer can stand the weight, I think that's the way to go rather than a trailer.
I also installed a front class 4 hitch on my truck and will tow our other bike there when towing the fifth wheel. I just finished and will take some photos this weekend, if you're interested, drop me a line.
2006 Duramax Diesel 1 ton dually tugging around a 2006 Mobile Suites 36TK3 #2609. Retired and just travelling around now and then seeing the sights.
3311
Posted: 11/14/02 12:24pm Link  |  Print  |  Notify Moderator
Thanks Clipper, I guess I'm not that concerned about seeing it when backing up because I can always unhook it and move it by hand. I'm more concerned with how it will track behind the 5er. Is yours pretty stable ? Do you get much movement side to side ?
Dennis
3311
Posted: 11/14/02 12:27pm Link  |  Print  |  Notify Moderator
Texatdurango,
My bikes weight is 950 lbs. so I don't think I can haul it like you do. Thanks for the response.
Dennis
Clipper
Posted: 11/14/02 01:02pm Link  |  Print  |  Notify Moderator
Yeah 3311, the boat is very stable when towed behind the 5er - just like it is when being towed behind the truck. If your bike trailer tows well single, it should be fine double. The whole rig (64ft total) is very stable and tows smoothly with no wobble or sway whatsoever.
What I meant about not being able to see the second trailer pertained to going forward as well as back. You can't see much of a smaller trailer behind a 5th wheel and it can be a little disconcerting if you're not sure it is still there. Just something to be aware of.
*This Message was edited on 14-Nov-02 01:05 PM by Clipper*
3311
Posted: 11/14/02 01:14pm Link  |  Print  |  Notify Moderator
Clipper, thanks again you given me some confidence to move forward with this idea.
Dennis
wizzard
Phoenix, AZ
Posted: 11/14/02 01:55pm Link  |  Print  |  Notify Moderator
I tow a small 6X8 foot trailer with my off road golf kart loaded on it, (see My Toy's), on a regular basis. It's a bear when backing up say in a gas station when you get boxed in so to speak. Towing is not a problem at with me - trailer tracks like a dream - can not assertain any sway at all.
Phoenix, Arizona
- But it's a dry heat!
'01 Dodge Diesel 2500 auto
'03 Keystone Cougar 276EFS
bbalazs
San Jose CA
Posted: 11/14/02 03:20pm Link  |  Print  |  Notify Moderator
If any one has a picture of how they welded the hitch to the back of the 5th I would appreciate it.
Email me at orf@3foot.com
MSBRAG
Fremont, Mi. & Palmetto, Fl.
Posted: 11/14/02 03:22pm Link  |  Print  |  Notify Moderator
In Michigan you have to stay within the 65 foot limit ( bumper to bumper ) and you must have an RV endorsement on your drivers licence to pull 2 trailers.....
STEVE & MARY
2001 FORD F-350
Forest River Sierra 38 Ft.
TOWED IN 48 STATES
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
