RV.Net Open Roads Forum: Posting Pictures Using TinyPic.Com For The Host Site
Search only in Forum Technical Support
Open Roads Forum  >  Forum Technical Support
 > Posting Pictures Using TinyPic.Com For The Host Site
Page of 9
Scottwig
Belvidere, IL
Posted: 01/28/10 11:24am Link  |  Quote  |  Print  |  Notify Moderator
take two....[/img]
Oh well, never mind it was a crummy pic anyway...
Scott and Janet Hartwig
Rocky and Moose, long-haired mini dachshunds
2006 Damon Daybreak 3270F (F53 V-10)
Tandem Tow Dolly with Honda 750s, Aero and Spirit C2, and Ford Focus
Scottwig
Belvidere, IL
Posted: 01/28/10 11:28am Link  |  Quote  |  Print  |  Notify Moderator
I told you it was a crummy pic....
JesLookin
Appleton,WI
Posted: 01/28/10 11:42am Link  |  Quote  |  Print  |  Notify Moderator
Here's mine.
2005 Sierra 285 BH
2003 Dodge 2500 Diesel, quad cab, short bed
pulsar
Lewisville, NC
Posted: 01/28/10 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
scottwig,
The tutorial, first post in the thread, states: "Select the IMG Code URL, second from the top, and paste it into a post or PM."
If you use the IMG CODE URL, you cannot use the message window's Image tool.
The tutorial goes on to discuss how do deal with a picture that exceeds the forum maximum dimensions. In this case you copy tinypic's Direct Link for Layouts and paste it into the Image tool and provide a size parameter.
Tom
moisheh
North America
Posted: 02/22/10 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Trial #2
width=640[/img]
moisheh
North America
Posted: 02/22/10 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
TRial #3
moisheh
North America
Posted: 02/22/10 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
Wow . I got it. So pls. correct me if I am wrong. You simply copy and paste the URL into the message and do not use the image window. Does this apply to other photo sites as well?
Thanks
Moisheh
pulsar
Lewisville, NC
Posted: 02/22/10 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
Not all host sites provide the same URLs. This tutorial for TinyPic.Com talks about using one of two URLs, depending on the size of the picture. If the picture does not exceed recommended maximums, then you use the IMG URL and paste it directly into the post. If the picture is too large, then you use the Direct link, past it into the Image tool and provide a width parameter. Using the IMG URL in the Image tool, as I believe you did above, will not work. Similarly, pasting the Direct link directly in the post will not work.
If you look at the syntax of these two URLs, you can probably identify the correct ones on other sites.
Tom
Sinton4616
Posted: 02/26/10 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Quick test.
Working in Iraq, no camping this year
2005 Dodge RAM 2500 Quad Cab, 4x4, Long Bed, CTD
2006 Fleetwood Prowler 3102BDS
walcoffl
So. California
Posted: 03/18/10 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Page of 9
